The semi-Comprehensive M60b40 into E30 swap Q&A
Oh damn! Thank you thank you.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
Hey M6x guys, I came across this document with LOTS of detailed technical info on the M62... Thought you guys might find it useful.
Zinno '89 <24v swap in progress>
http://www.meeknet.co.uk/E38/M62%20Engine%20Details.pdfMtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
Yeah I was trying to find out the difference in exterior dimensions (length) and weight between the S65 and M62 just out of curiosity. Couldn't find much useful info on that.
But I did find out that they have the same cylinder spacing(center to center).Zinno '89 <24v swap in progress>
Came across a reference today to the M62 and S62 using a crank sensor in the bellhousing reading a trigger wheel on the flywheel.
So be careful that your transmission will support the engine management you choose.
I already grabbed a 5 speed, so I'll have to modify the bellhousing to include the crank sensor for my S62 swap.
Also, check out www.car-parts.com for ANY used OE part you might want for swaps like this.Comment
The same S5D-310Z (320Z?) that everyone else is talking about. They were used in '94 & '95 E34 530i. They just have the V8 bellhousing pattern on the front.
What "kit" did you get? What's in it?Comment
Ahh... Ok, you got a complete pullout.
I was thinking "kit" meant mounts, wiring, right selection of hoses, etc.
Top gear in the 5 speed is 1:1, while top gear in the 6 speed is 0.83:1. They both have approximately the same 4.20:1 first gear.
With the 5 speed, you'll need a very tall rear end ratio to keep the RPM down on the highway.
Of course I expect you wouldn't log a lot of highway miles in DomRep.Comment
1989 LN106 Hilux / 3.0TD SFA
1974 2002tii / stock
2002 IS300 / 5spd LSDComment
I had a 3.73 mated to a zf320 in my e30 and I HATED it on the highway. My work commute is a 50/50 mix of highway and city driving so it gets old REALLY fast. I can definitely appreciate a lower revving more "refined" highway commute.Originally posted by ebelementsAlso, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.Comment
A 4.0-and even more a 4.4-when used with the non-overdrive ZF 5 speed could easily pull 2.56 or taller rear gear in a body as light as the E30. BMW makes them down to 2.35 for European diesel cars.
2.79 is the tallest that's easy to put in an E30 in the US, so we'll roll with that for an example. With the 4.20 first in the ZF and 2.79 rear, the overall ratio in first would be 11.7, which is quite aggressive. A V8 would be able to break tires loose at will in a RWD E30 with that first gear... especially if used with a lightweight flywheel and clutch.Comment
