Turbo 5.0 Swapped e30
  • FunfGan
    • Jan 2011
    • 4958
    I like you. Care to trade that car for my 3/4th finished 5.0 swap? :P
    Go here be happy!
    Ratchet Garage e30 V8 build.
    • omarquez510
      • Apr 2012
      • 64
      interior together, floorboards sprayed with rubber coating.
      turn signal stalk, shortened
      wiper arm deleted.
      Cheap and effective gauges from summit. Approx $15 each. I made the delete panels from free plastic scraps. Covered them with the 3M? Carbon Fiber film.
      • VANOS714
        • Nov 2011
        • 1195
        Very nice project. Around how much did you spend on this particular set up??
        • omarquez510
          • Apr 2012
          • 64
          Approximate Prices
          Car = 500
          2 Engines/1 trans = 700
          ECU/Harness = 100
          Turbo stuff = 900
          3 different MAF's!! () & injectors= 600
          Flywheel,Edelbrock intake/ Electric W/P = 325
          RX7 Brakes and Wheels = 600
          DIY coilovers g60 konis/450f 550r springs = 350
          Gauges = 125
          Swap mounts/modified oilpan/swap guide = 450
          Misc = 200
          Total cost = $4850
          • Jonsku
            • Oct 2004
            • 566
            Ouch, the stuff is very cheap there!
            - E34 M5 (x 2) -
            - E30 V8 Cabrio "Kylpyamme" -
            - Alpina D10 Touring #33/94 -
            - E46 318i Touring -
            - Toyota Hiace 4wd -
            • Mad_trbo
              • Jul 2012
              • 1
              More Images and update
              I am thinking on running this same setup. What is the verdict ?
              Also any more images of the set up, love to see how the exhaust is run. The manifolds as well.
              • omarquez510
                • Apr 2012
                • 64
                Sorry for the lack of updates. The car is back up and running and i will be posting info and pictures.
                The setup is running well, still not tuned. Now I'm working on poly bushings and getting some more miles on it.
                • eurotrash
                  • May 2007
                  • 768
                  Burnout vids or it didnt happen
                  • omarquez510
                    • Apr 2012
                    • 64
                    Pictures and gopro vids coming i promise. buying parts for this thing is nonstop. Probably need to order some stuff tonight.
                    Newest additons
                    -msd custom length 8.5
                    -vacuum pump/catch can setup
                    -lots of re-wiring added some relays/fuses.
                    -condor motor mounts
                    • omarquez510
                      • Apr 2012
                      • 64
                      Cv joint died. Tried replacing today, original shafts where rusted to hub bearing. Bearing got damaged from so much pounding to remove Cv shaft, now I get to do bearings haha.
                      Got around to wiring a battery disconnect. Need to add rivets bolts are kinda lame.
                      Sent from my SPH-L710 using Tapatalk 2
                      • omarquez510
                        • Apr 2012
                        • 64
                        Rear bearing fun
                        • IronFreak
                          • Dec 2012
                          • 3702
                          Love it dude, I'm in the process of the same build. I will be hitting you up from time to time with questions! I love the manifolds, where did you get them? Are they custom or brand specific?
                          Check my build and let me know if you have any suggestions.
                          Instagram @rebellionforge
                          • Exodus_2pt0
                            • 5943
                            This is awesome.
                            No E30 Club
                            • omarquez510
                              • Apr 2012
                              • 64
                              I've been dealing with overheating issues. Finally registered and street ready
                              I tried keeping the stock 325E radiator and I dont think its efficient enough to keep up with my electric water pump.
                              Just ordered a summit aluminum unit. 19x27.35x2.25
                              • omarquez510
                                • Apr 2012
                                • 64
                                Super late response, sorry. N/a manifolds were bbk shortys with v-bands. Turbo manifolds were custom built for a 94-95 5.0.
                                Hmu with any questions. I wish i wouldve documented the process to help others.
