Turbo 5.0 Swapped e30
    what radiator are you running mine gets a little warm some times when i am going for it on a hot day
      Going to try a summit 2-row radiator. I'll let you know how it handles the heat. I measure the max dimendions and stuffed it in there. Has room for dual fans and intercooler.
      19x27.35x2.25
      Free Shipping - Summit Racing™ Universal Fit Aluminum Radiators with qualifying orders of $109. Shop Radiators at Summit Racing.
        Im running an old nathans that a buddy had layin around from his nova. Same demensions as the e30 rad just like a 3" rather then 1" then cut out the rad support and moved rverything forward so i could fit a taurus fan behind it. Nvr gets above 192 now with the t fan.
          Haven't updated in a while. I've ditched the turbo setup and went with aluminum heads and a custom grind cam.
          This time around I'll be using a short block I rebuilt. I am going for a reliable build I don't have to monitor so closely like a boosted application.
          I'm pretty close to having this thing done. I'm waiting for a buddy to finish welding my exhaust flanges.
          This picture shows that e30v8 brackets need to be notched for clearance and reinforced as they started bowing.
          Relocated fuse box mocked up
          Radiator stuffed in there
          Shot of driver side header
          Sent from my SPH-L710 using Tapatalk
            Short idle video no exhaust yet.
              sick build!!! im hooked!
                Another small update. THR bushings came in and I wasn't feeling the fruity green. Stripped them and did a quick polish, then I finished them off with clear.
                  Finally got an exhaust welded up.
                    Been driving my e30 for about a month working out some bugs. Everything seems solid as of right now.
                    The wilwood slave/master/pedal kit has been a pain in the ass but I did my research and I made it work.
                    I'll post a link where I found the same problem and solution. Basically the threaded rod attached to the piston backs out and leaks at the the o-ring.
                    Slot pulsa xl kini menghadirkan slot telkomsel serta xl slot atau slot xl sebagai pilihan utama untuk memainkan slot deposit pulsa 10 ribu tanpa potongan.
                    Got my alignment done and got some random pictures.
                    Alignment
                    Camaro Kyb agx shocks.
                    Condor m20 mount
                    Homemade clutch slave bracket
                    Sent from my SAMSUNG-SM-G900A using Tapatalk
                      Can you post up complete pic's on your exhaust system how its routed.
                        Some videos from today before I broke another axle. Beat my buddies sti and another 5.0 with heads/cam/intake.
                          Cool videos sounds nice!
                            Messing around before work.
                            [yt]rgDvtVZtcW0[/yt]
                            http://www.youtube.com/watch?v=rgDvtVZtcW0
                              What size wheels and tires are you running with that much power
                              1990 S50 Calypso-rot 325i
                                225/45 falkens wheels are 15x8. They don't hook in 1st even with a 2.93diff. I really want to try a set of Hankook rs3's.
