MMP M62B44 Build Project "Jack-N-Coke"
  • MonkeyMadness
    • 3251
    #526
    Everything from the c101 and back check out.
    My problem is that with the c101 unplugged and the the key on the temp jumps to super hot.
    • JGood
      • Jan 2004
      • 7959
      #527
      And you don't have continuity from c101 pin 4 to chassis ground? If not, yeah, sounds like you fried something in the temp gauge, or maybe even the SI board, since that's where power to the gauge comes from.
      e30 restoration and V8 swap
      24 Hours of Lemons e30 build
      • MonkeyMadness
        • 3251
        #528
        Fuc...
        • MonkeyMadness
          • 3251
          #529
          Doing Exhaust...
          • CorvallisBMW
            Long Schlong Longhammer
            • 13039
            #530
            Very nice
            • delamaize
              • Nov 2013
              • 1463
              #531
              'Rah.
              Dumpster Fire Pilot
              • Denny
                • Jan 2010
                • 822
                #532
                oh hell yeah!!
                Denny
                ___________
                1990 BMW red 325IC M30B35 all stock Girlfriends ride
                1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
                Blogs:
                http://bmw325e30.blogspot.com/ (restoration)
                http://bmw325e30turbo.blogspot.com (Twincharge M20)
                http://bmw325e30m62b44.blogspot.ca/
                • MonkeyMadness
                  • 3251
                  #533
                  Tails forward to trans mockup.
                  I like it so far..:)
                  • MonkeyMadness
                    • 3251
                    #534
                    Finished with mockup. Tomorrow tack and final weld.
                    Then burn tires... post vid ;)
                    • Yorl
                      • Mar 2012
                      • 172
                      #535
                      Looking good!!! Needs more supercharger though.... ;)
                      • MonkeyMadness
                        • 3251
                        #536
                        Yup....
                        • Denny
                          • Jan 2010
                          • 822
                          #537
                          Yup....
                          no H-Pipe? or X-pipe? ....hmmm wait... I see some little black marks there...
                          Denny
                          ___________
                          Blogs:
                          • MonkeyMadness
                            • 3251
                            #538
                            So I think my little temp sensor test messed up more than just my temp gauge/is board.
                            After installing my newly built exhaust i started the car to hear it roar! And noticed it was hard to start and had a rough idle. Then i noticed that it has a bad bog when giving it throttle.
                            I'mthinking when i was screwing around with the two temp sensors (ecu & temp gauge) that not only did I touch the temp gauge plug with a hot wire but i also attached at one point the hot to the ecu temp plug. Seeing how it f-ed up my temp gauge. I'm thinking it also hurt my 404 dme.
                            Damn it.. :-(
                            • artoo93
                              • 909
                              #539
                              I have read this thread completely 3 times!! Just giving myself more incentive to get mine done!!! There is a lot of good info within these pages and I will be referring to this again and again! Got more done on mine this weekend with reinstalling the dash wiring and figuring out some more of the brakes! Wish I had just a small bit of your fab abilities! Would make this that much easier! Really like the exhaust as I want to have that "sleeper" look when I am finished. Awesome job!!! Really excited to see how the SC is going to change things!!!
                              Some people just need a sympathetic pat...
                              on the head...
                              WITH A HAMMER!!!
                              • MonkeyMadness
                                • 3251
                                #540
                                Thanks to the above post ^^^^ :-D
                                So took the car for a test run yesterday and noticed a "check engine"
                                Light. Ugh
                                Did a stomp test and found that the repeating (temp sensor)code is 1223 pause 1223 and just keeps going never stopping..
                                So i tried clearing it many ways with no result. Ugh...
                                So now i know my dme is hurt.
                                Not too worried, i have another one. Just have to pick it up.
                                So upon driving the car with the new exhaust. Its still loud at WOT sexy at idle and has the sic euro v8 sound when blipping and revving the rpms
                                All in all its still loud. But no louder than an uncorked mustang. Which seems to be the norm in this area.
                                I can tell you that I am not worried about attracking the poo poo while rollin my hood G.....
