From Boost to Reliable. M62b44 Swap!
  • Zacm829
    • Jan 2008
    • 1919
    #121
    Passenger side is an unmodified e53 manifold, we are going to have to do a little conditioning to make them work.
    1987 325i-M60b44 swap
    • LoneWolf
      • 402
      #122
      Gotcha. What is the problem? Where the flange goes down to the exhaust?
      Or not enough clearance between the frame rail and manifold?
      • The Dark Side of Will
        • Jun 2010
        • 2796
        #123
        Does it clear the E30 firewall, or does it need to be carved up before the engine even goes into the bay?
        • Zacm829
          • Jan 2008
          • 1919
          #124
          I'll let Matt chime in on those questions, I havent had a chance to actually see the headers in the car yet.
          Unrelated update, sold the esms and had these shipped over from Germany!
            • Jun 2010
            • 2796
            #125
            One step closer!
            To clarify, I was asking if this manifold clears the firewall and/or frame rail.
            • dougie30
              • Apr 2012
              • 1708
              #126
              quick question, that is a five speed trans correct? thats why you had to weld the cps tab on the front timing cover?
              also if it is the five speed, the original duel mass flywheel was compatible with it?
              M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
              • Zacm829
                • Jan 2008
                • 1919
                #127
                Yep, using 5 speed tranny. We welded the cps mount becasue we converted the motor the OBD1, garagistic's website http://garagistic.com/index.php?page...-using-m60-dme helped a bit with the modifications need and we used a feeler gauge on a complete m60 to get our spacing correct.
                For the flywheel I went with an e39 M5 dual mass flywheel, with e39 530i clutch.
                • dougie30
                  • Apr 2012
                  • 1708
                  #128
                  Thank you I appreciate the feed back!
                  • whysimon
                    • Jan 2007
                    • 663
                    #129
                    where did you get the flywheel from?
                    • Zacm829
                      • Jan 2008
                      • 1919
                      #130
                      I looked around and finally found the flywheel used off of a 55k mile m5 on ebay. It looks good with no hotspots so I'm going to run it as is.
                      • Zacm829
                        • Jan 2008
                        • 1919
                        #131
                        Long overdue update, Mattdk ended up moving farther away but to a house with a big shop and he added a lift. I headed down last weekend to put in some wrench time.
                        Much easier access on a lift!
                        First since we were able to get the car in the air, we decided to tackle finishing up the transmisson and driveshaft. Needed to lengthen the shift carrier and selector rod. Also threw in the e36 m3 drivesharft.
                        • Zacm829
                          • Jan 2008
                          • 1919
                          #132
                          Next we set her down on the ground and noticed the cam position sensor (M60) is being contacted when the motor is turned over. Anyone modidfed the cam wheel like in this thread to run an m62 obd1? http://www.bimmerforums.com/forum/sh...l-modification
                          Anyway back on the ground.
                          We had pleanty of examples to compare the m62 with to make sure we had the correct sensor.
                          Parked the topless mt2 and called it a night.
                          We spend most of saturday working on the oil filter relocation. After several ideas and attemps we decided to move the filter housing to behind the passengers headlight. We repurposed some m20 oil cooler lines and added some DOM tubing, after and lot of tack welding and finalizing I think it came out pretty well. We still need to pressure test and paint it.
                          Still need to weld/paint to finish this mounting plate up.
                          The big hurdles left are power steering lines and wiring. Also some small odds and ends to tie up after we figure out this cam sensor issue.
                          • agent
                            Vice Grand Pubaa
                            • 7960
                            #133
                            Woohoo, progress!
                            Tell Matt congrats on the new digs.
                            Originally posted by kronus
                            • mattdk318i
                              • Jun 2006
                              • 3953
                              #134
                              Thanks man!
                              • mattdk318i
                                • Jun 2006
                                • 3953
                                #135
                                The shop is chaos, still dont have any of the equipment hooked up. Slowing getting everything where i need it.
