From Boost to Reliable. M62b44 Swap!
  • LoneWolf
    • 402
    #91
    Awesome job on the engine mounts. I like how you eliminated the need for the oil line plate by incorporating your own into your mount.
    That plasma table has to be a sweet tool to have, I'm stuck drawing them in CAD, tracing them, and then doing the plasma by hand.
    • mattdk318i
      • Jun 2006
      • 3953
      #92
      Thanks man, Actually sold my e30 for the money to build the table. It was hard to let her go. Still dont have a e30...
      • The Dark Side of Will
        • Jun 2010
        • 2796
        #93
        Yeah, that's a seriously nice tool.
        • JGood
          • Jan 2004
          • 7959
          #94
          Haha, I felt like I was looking through my own build thread for the brake setup, except it got done in 1/10th the time, with 1/10th the aggravation, and looks better. I seriously envy your tools and fab skills. Nice work.
          e30 restoration and V8 swap
          24 Hours of Lemons e30 build
          • Zacm829
            • Jan 2008
            • 1919
            #95
            Progress
            I was able to shoot down to columbia last weekend to help Matt knock out some of the work. The plan was for him to finish the chassis while I worked on resealing the motor to get it ready to drop in. We ended up working 18 hours that weekend, makes me miss winter.
            Scored an OBD1 setup and 404 DME at the Charlotte LKQ before I headed south.
            Resealing the motor/Replacing timing chain guides/Retiming the motor.
            Dk welding on the rear coolant pipe for firewall clearance.
            Found a problem with mounting the m60 water pump to the m62, seems the casing of the pump is larger and interferes with the m62 timing cover bolt. This was the case on our pump at least . Nothing an angle grinder couldnt fix.
            Had Dk cut out a rear blockoff plate for the m60 manifold , cleans up the rear nicely.
            Now came the time to mount the OBD1 CPS on the m62 timing cover, we decided the cast mount looks terrible so we drew up our own.
            Welded/Painted/Mounted
            Got the chassis ready for its new motor and the engine is just waiting on the clutch setup. I plan on using e39 M5 flywheel/e39 530i Clutch disc/M5 pressure plate. Once that and the transmission refresh kit arrive we will be in business.
            Some exhaust parts showed up! :nice:
            Some future plans a la Monkey Madness...
            I'm heading back to Lown Performance next week so stay tuned for updates!
            1987 325i-M60b44 swap
            • LoneWolf
              • 402
              #96
              More good progress. Good work.
                • Jun 2010
                • 2796
                #97
                Can't use the M60 timing cover or just didn't have one?
                • mattdk318i
                  • Jun 2006
                  • 3953
                  #98
                  The m60 cover is a diff design due to dual row chain. This is the easiest solution. The design changes makes the covers just different enough to where they leak.
                    • Jun 2010
                    • 2796
                    #99
                    Ahh, ok. Didn't know that. Carry on! :)
                    • Zacm829
                      • Jan 2008
                      • 1919
                      #100
                      I was able to get down to Columbia this week and help out. My M5/530i clutch setup had arrived as well as my Spintech muffler. This muffler with the Vibrant resonators should sound great! We also modified a T-60 bit to be able to install the flywheel!
                      • Zacm829
                        • Jan 2008
                        • 1919
                        #101
                        I bought the transmission with a hole in the bellhousing, looks like someone got a little frustrated! :up: Matt preheated, welded, then made sure we had even cooling of the cast bellhousing. Also did some strengthening to the subframe for the added v8 torque.
                        • Zacm829
                          • Jan 2008
                          • 1919
                          #102
                          Dk's solution to our lack of a coolant expansion tank. Fit is great asnd should work well.
                          Stay Tuned
                          • Ether-D
                            • Sep 2011
                            • 2838
                            #103
                            Awwwwww yeah.
                            The m90 (if that's an m90) may be a little small for that motor though. It'll probably still work. It just may make quite a bit of heat. But I say do dat shit.
                            Originally posted by Andy.B
                            I was born on 3/25…
                            • Jean
                              • 18228
                              #104
                              Nice progress man!
                              Q. Did you end up going with a oem dual mass flywheel?
                              • e30m3s54turbo
                                • Jun 2010
                                • 3292
                                #105
                                Awesome fab work and project!!!
