*Updated & only kinda shitty now!* The definitive 5.0/302 swap guide
  • grant_jr
    • Jul 2012
    • 62
    #31
    Just grabbed the block with the crank, pistons and rods, buying new heads (trick flo or pro comp). Drove for 2 hours, paid $120. I will start a thread when i get some kind of progress going.
    • jalopi
      • 2370
      #32
      i hear trick flows are good, but that afr's are the shit. sbf tech should be a good source of info for head debates.
      • grant_jr
        • Jul 2012
        • 62
        #33
        Yeah I heard the same but they are super pricey(for good reason of course). I am planning on backing up the heads with a cam to hopefully reach my power goals.
        • e30_302
          • Sep 2013
          • 453
          #34
          Be careful on the Pro Comp heads....
          • jalopi
            • 2370
            #35
            now that I think about it... isn't pro comp some sort of crap ebay brand? I've heard of people having to do machine work out of the box or something.. if they're the $6-700 pair of heads then they're the ones I'm thinking of.
            • e30_302
              • Sep 2013
              • 453
              #36
              ProComp = ebay China heads. Hit or miss. There is an aluminum GT40 replica head on ebay that is made in Australia that's apparently ok.
              • aaron.j
                • Jan 2006
                • 529
                #37
                If you get the pro comps bare and assemble them with good parts they are a decent enough head. Afr 165 will limit you if you ever go bigger than a 302. Trick flow fast as cast are the ones to have for a stock bottom end with future upgrades in mind. Edelbrock e streets are good too.
                • grant_jr
                  • Jul 2012
                  • 62
                  #38
                  yeah i noticed i couldn't find them any where else but ebay so going with a set of trick flows from summit
                  • brahbarian
                    • Mar 2012
                    • 153
                    #39
                    good tips here. im very interested in doing a 5.0 swap.
                    around how much you folks got into this swap?
                    i know itll depend a lot on what ill be doing.
                    • jalopi
                      • 2370
                      #40
                      Here's my basic parts list for a respectable carb'd setup
                      I'll add this to the first post soon:
                      1. Block (got mine for) - $300
                      2. Heads - $1200+ (mine were 1200)
                      3. Rockers, pushrods - $400
                      4. Cam - $250
                      5. Tranny - $400-1200 (bought a rebuilt one. Didn't have a press at the time)
                      6. Clutch - $350 (for one that will hold up to your power levels)
                      7. Carb, filter, intake - $500
                      8. Driveshaft - $300
                      9. 3G alternator +wiring - $200
                      10. Adequate radiator - $200-300 (I got the mishimoto z3 rad, not enough clearance imo)
                      11. Oil pan modification - $80 (although this was done through the shop I used to work for. Not sure how much it would cost to have it modified walking in off the street)
                      12. HP/HF oil pump - $100 (I think. Milodon was the one I went with. price includes hardened driveshaft, which is recommended for a high pressure, high flow pump)
                      13. Gauges - $150-600 (this is what can get surprisingly expensive really fast. I bought electrical gauges [which I recommend... hot fluids in the passenger compartment suck] and the fancy ultralites at that too)
                      All those numbers (for what I bought and recommend) add up to $5780. There's some little stuff I'm missing, like rings, bearings, gasket set, ect so we'll say $6k for now. Just bought a chopsaw and I'm ordering some pipe from summit so I can make a real exhaust. Hopefully I'll spend less than $500 on the exhaust (yes, it could be done for much less, but I want a quiet muffler and an electric cutout so that really adds to the cost)
                      • e30_302
                        • Sep 2013
                        • 453
                        #41
                        You could do a stock 5.0 swap for $1,000 if you've got a well stocked junkyard you can go to and can do the fabrication stuff yourself. In the race car I'm probably at about $2,000 for the swap components and accessories, but we got the engine from a JY for $250 and I got a T-5Z trans, clutch/plate, bellhousing, flywheel for $600.
                        • jalopi
                          • 2370
                          #42
                          I can't figure out why people go through the trouble and inconveniences of having a v8 e30 for 200-220whp... and that's with a fuel injected h.o. running good.
                          • e30_302
                            • Sep 2013
                            • 453
                            #43
                            300#'s of torque to go along with that 225 HP rating. Calculating horsepower is a function of RPM....and those engine's don't rev. A stock 5.0L would be plenty rewarding, I think, until you could afford some upgrades.
                            • eurotrash
                              • May 2007
                              • 768
                              #44
                              This swap cant be done properly with 1k. Realisticly even fabbing everything yourself your looking $2000. That will get you engine/tranny/driveline/clutch/pedal/odds and ends/mounts/pan. Thats assuming your dumping the exhaust and not routing it back. You can cut costs and pick stuff up for cheaper here and there but id say for a well sorted setup that isnt hacked together your looking at closer to 4k and thats a stock setup. You'll be spending $1000 on the pedal/slave/pedal box/mc setup alone to do it the right way. Figure $1000 on exhaust for headers and a not hackjob custom. (Thats assuming you dont have the know how to build your own . 95% dont) engine and tranny will realisticly be 500-1000 for a stock/mild built setup.
                              You've got another $500-1000 in random parts(mounts/pan/filter relocation or cooler, gauges, accesory mount stuff (assuming your at least yarding the ac)
                              500-1000 in cooling componants( rad /fan /switch setups)
                              Biggest costs that will sneak up on you are exhausts and pedal stuff. I live im bumfuck wa and still got stopped and warned for my dumps. You will need an exhaust of some sort. You can hack together a wilwood pedal setup and even make the booster delete yourself but its gonna be a hodgepodge of shit that will either fail on you or just look hacked together.
                              • e30_302
                                • Sep 2013
                                • 453
                                #45
                                $1,000 for pedal, MC, etc? What all are you using?
                                Here's what I've done:
                                Massive booster delete: $175
                                Master Cylinder: $75
                                T5 Hydro conversion: $165
                                Clutch line: $40
                                Throttle Pedal + Cable: $100
                                =$515
                                So yeah, $1,000 is probably unrealistic. I guess I'm in denial on how much I've spent and don't like to think about it too hard.
