*Updated & only kinda shitty now!* The definitive 5.0/302 swap guide
Yes you need to change the pivot point on the pedal for increased leverage. The Massive booster delete kit spells it out and has the necessary hardware. The T5 is cable operated, need to convert to add a hydro slave if you want to stay hydraulic. Not hard, there's a kit for that too.If you guys are running manual brakes (no booster) have you thought of changing thhe leverage point on the pedal? My friend is doing it and personally, i havnt seen how easy it is but it sounds like a good idea. Also, i asked in the general tech section, but apparently everyone ignored me. I couldnt find a DIY section dedicated to the front mounted booster/mc. Anybody has some info or links on that? Im close to start my 5.0 swap and im trying to get all the knowledge i can. So far, this thread has tons of info. Pretty cool by the way.also, why doesnt the stock e30 clutch doesnt work with the T5 slave? Thanks in advancesigpicComment
I think this is detailed in my build thread as well, but I used a Dorman H38117 slave that is for an 80's Nissan pickup. It looks almost exactly like the Nissan 280ZX slave others have used but the inlet and bleeder are easier to access. Because of the tight trans tunnel I mounted it tight to the T5 and drilled a new hole in the clutch fork closer in to the T5. I am using the e30 master and it works great so far.Comment
holy fuck, seriously? goddamnit.... oh well, live and learn I guess, would've loved to keep my stock pedal :/Mine works perfectly with this kit.
is your pedal stiff though? I've got a ACT clutch kit rated to 450ish or something wheel torque and my clutch pedal effort is stock honda level.
As far as bellhousings go you've gotta get the correct one for your transmission. If you can source a t5 from a 94-95 mustang the shifter will line up in the existing hole better. However, the input shaft is about 1" longer than the t5's out of the fox mustangs, so you've gotta get a bellhousing for a 94-95 while you're at it.Comment
Cool that's a lot of gold, especially with the trans tunnel hole. Clutches are whatever pretty straight forward. What about drive shaft set up. I've read to save our e30 shaft and grab the yoke for the t5 but I've read we can use the mustang shaft with a diff flange for our med case. Just want a better understanding. Build thread soon. :)
Get a driveshaft made from scratch. Including parts I had to buy online it was about $400 total for a custom shaft. I bought a ford racing (or whatever you want) t5 yoke and a diff flange from here:
Question:
Currently planning the suspension/braking system of the car, and was wondering if any of you are running 5 lug brakes (whether they be M3, 330i, etc). Will this be an issue when running manual brakes? What size master cylinder would be ideal?Comment
