My M60 swap
  • Zacm829
    • Jan 2008
    • 1919
    #76
    Looking good!
    Didnt know if you saw this pop up!
    1987 325i-M60b44 swap
    • Jack89i
      • Dec 2013
      • 240
      #77
      Thanks! I'm going today to look at a zf310 I found on car-part.com and I found an m60 as well
      Sent from my iPhone using Tapatalk - now Free
      sigpic'89 325i
      M60 swap in progress
      • Jack89i
        • Dec 2013
        • 240
        #78
        Got the transmission today!
        sigpic'89 325i
        • Jack89i
          • Dec 2013
          • 240
          #79
          Saw this at the salvage yard when I got the transmission..kind of tempting
          sigpic'89 325i
          • Jack89i
            • Dec 2013
            • 240
            #80
            Ok got the engine today..112k miles from a 94 740i
            sigpic'89 325i
            • Jack89i
              • Dec 2013
              • 240
              #81
              Lots of water..
              sigpic'89 325i
              • Jack89i
                • Dec 2013
                • 240
                #82
                sigpic'89 325i
                • Jack89i
                  • Dec 2013
                  • 240
                  #83
                  sigpic'89 325i
                  • alco
                    • Feb 2013
                    • 197
                    #84
                    Doesn't look good...
                    Velocity Motor Works
                    1972 2002
                    1983 533is
                    1987 325is (Roxanne)
                    1988 M6
                    1989 M3
                    1989 325ix (Darth Maul)
                    Gone: 1974 2002, 1984 318i , 1985 318i, 1988 325ix Sedan, 1988 325ix Coupe, 1991 318is, 1991 318i, 1994 525iT, 1995 325is, 1996 M3 Coupe, 1997 328is, 2001 325i, 2001 Z3 2.5i, 2001 330i, 2001 525iT, 2006 F-250 SD and more...
                    • Jack89i
                      • Dec 2013
                      • 240
                      #85
                      Yea..I'm about done with this..I drove out there twice, spent $100 on gas all for nothing. Looks like that fucker changed his oil every 20k..
                      I wonder how much I can get for an engineless e30
                      sigpic'89 325i
                      • jalopi
                        • 2370
                        #86
                        Is that rust covering the cam lobes & lifters?? That bitch must've been in the yard for a good long while.
                        All that aside, sorry to hear about the bad luck bro. You might wanna consider completely rebuilding something in the future... I'd be way too anxious to slap a 10+ year old mystery engine in my car. Either that or buy a running 540 with a destroyed auto tranny (don't know how things are in NC, but in Baltimore we've got sooooo many old luxury cars in states of disrepair [the city specifically])
                        • irrelevante30
                          • Apr 2013
                          • 100
                          #87
                          damn that sucks
                          • DesertBMW
                            • Aug 2011
                            • 1028
                            #88
                            Originally posted by irrelevante30
                            damn that sucks
                            Why are people buying already pulled engines that sat in the guy's yard for forever? Just looking at the main pulley, all rusted out. It is just common sense not to buy engine that got rained on.
                            It was like 650 with the trans
                            People want to go cheap with swaps, it just does not work
                            • alco
                              • Feb 2013
                              • 197
                              #89
                              Honestly, this is about the worst luck I've ever seen any one individual experience. Take it all back on account of engine is fucked. If you're not interested in continuing, cut out before you invest any more. If the rolling chassis you now have is in good shape you should be able to get a few hundred for it but it'd be best if it were running under its own power. Sounds like your best bet is to buy a running M20 (witness it running) put it back in and enjoy the car. Don't forget to do the timing belt when you buy said M20.
                              1972 2002
                              1983 533is
                              1988 M6
                              1989 M3
                              • The Dark Side of Will
                                • Jun 2010
                                • 2796
                                #90
                                Try pulling the cams and see if that will clean up with scotchbrite. Flash rust on cam lobes can frequently clean up and be run just fine. Even pitting will run fine as long as it's on the base circle and not where the lobe lifts the valve.
                                I'd only do that as a last resort, however. Can you take it back and look at another engine while you're there? IE, pull the valve covers for inspection before you leave with it.
                                Rust on the main pulley doesn't indicate much of anything. That area of the pulley is bare polished steel, thanks to contact and friction with the belt. It's like a brake rotor... it'll be rusty if the car's sat longer than a week.
                                The engine *SHOULD BE* sealed well enough that being rained on doesn't hurt it. After all, it gets sprayed down whenever the car is driven in the rain. So whoever pulled it had to have left SOMETHING wide open to the weather for a while.
                                Engine swaps can be done cheaply, but need to be done carefully.
                                And if you check www.car-parts.com for '94 740i engines in North Carolina, you'll find that $650 is right in the middle of the pack in terms of price.
