M60/62 Turbo kit....in the works
  • TSI
    • Mar 2012
    • 691
    #76
    Originally posted by King Mufasa
    [IMG][/IMG]
    I stand corrected. With removing chassis members everything is possible.
    • driftingminor913
      • Sep 2011
      • 358
      #77
      Any ideas? Folks? On the wastegate question?
      Because V8
      http://www.r3vlimited.com/board/showthread.php?t=282219
      Doing it wrong since 91:wgaf:
      • driftingminor913
        • Sep 2011
        • 358
        #78
        YAY! Building oil lines
        Because V8
        • Pootis
          • 636
          #79
          You will be fine with that size wastegate.
          1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
          COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
          • CarsonE30
            • Jun 2015
            • 2124
            #80
            I love this stuff, I have so much respect for the guys that build these and make go faster dreams a reality, from Kamotors and their M20 kit, TurboJake and his M42 kit and now this. Every BMW I own will be boosted thanks to r3v. Obviously subbed!
            C6Z
            S2K
            VeloN
            • TimeMachinE30
              • Jun 2014
              • 3749
              #81
              As an E38 owner.. I need to convince myself I would never need this.
              ACS S3 Build / Dinan 5 E34
              • driftingminor913
                • Sep 2011
                • 358
                #82
                Hahahaha yea I have always wanted to Build something plus I do my own fabrication work at home. Plus i haven't seen to many of these in the states on the road boosted n running and it's usually cause people get pushed away cause they can't fit the turbo or tuning purposes. So with this I can atleast get rid of the mechanical side of it n just leave the tuning to the owner
                Because V8
                • CorvallisBMW
                  Long Schlong Longhammer
                  • 13039
                  #83
                  paging 10Toes....
                  • econti
                    • May 2014
                    • 1145
                    #84
                    Subscribing for interest
                    E34 540 turbo would be tits
                    • CarsonE30
                      • Jun 2015
                      • 2124
                      #85
                      E34 540 owner here, I'll gladly be a test dummy!
                      C6Z
                      S2K
                      VeloN
                      • driftingminor913
                        • Sep 2011
                        • 358
                        #86
                        I'm sure I can make these fit in a e34 jury have to make the collector not so tall like I did on this one.
                        Because V8
                        • CarsonE30
                          • Jun 2015
                          • 2124
                          #87
                          If you need a donor car, I'm here!
                          C6Z
                          S2K
                          VeloN
                          • driftingminor913
                            • Sep 2011
                            • 358
                            #88
                            Things are moving nicely on the build had my local machine shop make my oil plate for the AN lines to the oil filter housing. 6061 Aluminum with -10 steel fittings , if anyone wants one let me know or message me would be great for going AN or if you want to put your filter else where you can with this since these fittings are able to
                            Because V8
                            • driftingminor913
                              • Sep 2011
                              • 358
                              #89
                              Going to get new seals since the OEM ones don't look sufficient to me. But the when I bolted it up I'm sure it was sealed
                              Because V8
                              • driftingminor913
                                • Sep 2011
                                • 358
                                #90
                                FINALLY DONE WITH THE MANIFOLD! Effffing Christ! Let me know if you have questions.
                                Because V8
