E30ls1
  • Reyhan335
    • Nov 2015
    • 700
    #571
    the pcm started another car...bleh
    i was hoping it would be that
    now to get all new sensors from GM since the ones i got from Advance are apparently not as good as the oem ones.
    e30Ls1 Swap IG: 1dirty30
    • TeXJ
      • 1914
      #572
      ouch man, well at least you're one step closer to releasing the beast.
      1990 325is
      m52b28
      3.73lsd
      g260 (1987 325is 5spd tranny)
      • Nick_08
        • 165
        #573
        Don't go wasting money on stuff hoping you're gonna fix it. You need to figure out why you're not getting fuel. As long as you're sure you have spark... I would start with starting fluid.
        -Nick
        • Reyhan335
          • Nov 2015
          • 700
          #574
          fuel pump primes and i took the hose off, put the hose in the bucket turned the ignition on and let it rip. fuel was coming out into the bucket.
          and i know i have spark for sure.
          • Q8y_drifter
            • Aug 2009
            • 297
            #575
            If the injectors are not firing then u still wont get fuel into the engine.
            Alpine White 1989 E30 Coupe - LS1/T56
            • Reyhan335
              • Nov 2015
              • 700
              #576
              I didn't check injectors because I didn't think all 8 would go bad at once.
              • Pootis
                • 636
                #577
                Take the rail off put each injector in a water bottle hit the key you will know pretty quick
                1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
                COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
                • Nick_08
                  • 165
                  #578
                  I don't think you get it.... so good luck dude.
                  -Nick
                  • sgtskid
                    • 763
                    #579
                    ^ buy something similar to this and plug them into the injector harness. Turn the car over. If they don't light up, your injectors are not getting signal to fire. Regardless of how much pressure is at the rail or if the pump is working, if the injectors aren't firing no fuel is getting into the engine.
                    As someone mentioned earlier, spray a quick shot of Ether into the throttle body (don't over do it) as your cranking the car. If it starts, you have an answer and a defined system to troubleshoot.
                    Current: '91 DS M3, '03 TS M3 (6MT)
                    '06 Chevy 2500 Duramax - Race car hauler, '90 Corvette - Weekend toy
                    Past: '88 AW M3, '87 RB M6, '98 CS M3, '88 DS M3, '88 Zinno M3, '88 AW SETA (facelift),
                    1988 Super E (Bronzit - grey wrap)- RIP, 1986 353, 1986 VW Jetta (vr6) - Racecar
                    IG: RDE_Fabrications
                    Check us out
                    Or YouTube --> HERE;
                    • Reyhan335
                      • Nov 2015
                      • 700
                      #580
                      i'm getting the PCM back tomorrow so i'll get a can and try it out
                      • The Dark Side of Will
                        • Jun 2010
                        • 2796
                        #581
                        If there's an injector wiring problem or blown injector fuses, the injectors won't fire.
                        Using the starting fluid is an essential troubleshooting step to determine whether the problem is "upstream" or "downstream" of the fuel delivery.
                        If the engine fires and runs on starting fluid, that means that the crank triggering and ignition systems are working correctly and the problem is with fuel delivery.
                        If the engine doesn't fire on starting fluid, that means there's a problem with the crank triggering or ignition systems.
                        If your not smelling fuel after extended cranking, you're probably not getting fuel into the engine at all.
                        • Reyhan335
                          • Nov 2015
                          • 700
                          #582
                          starts on starting fluid.
                          took the injectors out and they're spraying but it looks weak
                          drained all the old gas out and put new gas in it hoping that would fix it.
                          still the same.
                          going to get a fuel pressure gauge tonight and test it again.
                          • Nick_08
                            • 165
                            #583
                            So it must be low fuel pressure? Do you have a new regulator? What if you cycle the key/fuel pump a few times. Will it build enough pressure then?
                            Do yourself a favor and get a nice fuel pressure kit that will connect to the schrader valve.
                            -Nick
                            • Reyhan335
                              • Nov 2015
                              • 700
                              #584
                              checking the fuel pressure tonight. i cycled the key a ton of times and still nothing. i had the fuel pressure kit on it like a month ago when it started the last time, and it was at 60psi. i guess we will see tonight what it's at. if it's at the 60 then it's injectors.
                              • Reyhan335
                                • Nov 2015
                                • 700
                                #585
                                Fuel pressure is at 2psi...
                                Also volt meter to the wiring harness ignition clips only have 6 volts
