E30ls1
  • Reyhan335
    • Nov 2015
    • 700
    #616
    Alright guys. It's been a while since I've updated anything.
    She starts beautifully now. Had a huge coolant leak. Bought another radiator and just got it back today. Carpet is in. Waiting on a check valve for my air ride and then it's just cleaning up wiring from there
    e30Ls1 Swap IG: 1dirty30
    • sgtskid
      • 763
      #617
      Current: '91 DS M3, '03 TS M3 (6MT)
      '06 Chevy 2500 Duramax - Race car hauler, '90 Corvette - Weekend toy
      Past: '88 AW M3, '87 RB M6, '98 CS M3, '88 DS M3, '88 Zinno M3, '88 AW SETA (facelift),
      1988 Super E (Bronzit - grey wrap)- RIP, 1986 353, 1986 VW Jetta (vr6) - Racecar
      IG: RDE_Fabrications
      Check us out
      Or YouTube --> HERE;
      • Reyhan335
        • Nov 2015
        • 700
        #618
        Car was running fine. Out of nowhere. Died. I thought it was the battery. Just checked and it's this. Car won't even get power when I turn the key.
        • Reyhan335
          • Nov 2015
          • 700
          #619
          Power block under the hood has no power at all. Is there a main fuse somewhere ?
          • jpod999
            • Dec 2015
            • 1401
            #620
            Maybe you blew the fusible link. It's an inline fuse that I think is in the trunk on the + line.
            OBDI M62B44/6 swap
            Transaction feedback
            - jpod999
            • Reyhan335
              • Nov 2015
              • 700
              #621
              going to check it tonight. hopefully that's it.
              • Reyhan335
                • Nov 2015
                • 700
                #622
                Looks good to me:/ I was hoping it would be this
                • sgtskid
                  • 763
                  #623
                  The fuse box has a direct line from the battery. If it doesn't have power, there is a loose/bad wire somewhere between the battery, junction block, fuse block.
                  Check the posts on the battery make sure they are clean and tight.
                  The battery wire looks awful. Did it get smashed in the install or something?
                  Check us out
                  • wspellmann
                    • Sep 2016
                    • 110
                    #624
                    Good luck to you, my father spend almost $2k getting a local shop to find the broken connection in my E30 while he still owned it.
                    My current E30 M62B44 swap
                    • The Dark Side of Will
                      • Jun 2010
                      • 2796
                      #625
                      You... umm... need to replace that.
                      • Reyhan335
                        • Nov 2015
                        • 700
                        #626
                        damn...i'm glad you told me that. i was just going to put it back on..
                        • Reyhan335
                          • Nov 2015
                          • 700
                          #627
                          this car doesn't want an LS1 in it
                          • Reyhan335
                            • Nov 2015
                            • 700
                            #628
                            And she's back running. I don't like the way the headers are too close to the wires for the starter. I wrapped them with heat sleeves. Hopefully it'll be fine
                            • Reyhan335
                              • Nov 2015
                              • 700
                              #629
                              Videos of it running is on my Instagram. 1dirty30
                              Can't figure out how to post videos on here. Now it's down to the little things. Just need time.
                              • shiboujin
                                • Feb 2006
                                • 2791
                                #630
                                First off, faux pas for using the term "dirty thirty".
                                Secondly - https://www.instagram.com/p/BVBVsl-Dm-4/
