E30ls1
  • Nick_08
    • 165
    #556
    Another thought is you can connect an OBD scanner and make sure the PCM is on and sensors are reading appropriately. You did wire in an OBD port...right?
    -Nick
    • Reyhan335
      • Nov 2015
      • 700
      #557
      Originally posted by Nick_08
      Did you test for spark? And confirm fuel? The fuel pump cycles?
      If you have spark and fuel it ought to fire... recheck all of the connections.
      yes, yes, and yes
      e30Ls1 Swap IG: 1dirty30
      • Nick_08
        • 165
        #558
        Originally posted by Reyhan335
        yes, yes, and yes
        I don't believe you. Unless you have no compression or the timing is off which is highly unlikely.
        It has to be one of the three.
        -Nick
        • Reyhan335
          • Nov 2015
          • 700
          #559
          dude i don't understand it at all. checked spark. yes.
          checked fuel. yes
          jumped the starter fuel was coming out
          but it wouldn't turn on.
          i'm shocked too man
          • Q8y_drifter
            • Aug 2009
            • 297
            #560
            Crank and cam sensors hooked up?
            Alpine White 1989 E30 Coupe - LS1/T56
            • Reyhan335
              • Nov 2015
              • 700
              #561
              everything hooked up just like it was a couple weeks ago when it was running.
              • Nick_08
                • 165
                #562
                I don't think he would have spark or fuel if they weren't working.
                -Nick
                • Q8y_drifter
                  • Aug 2009
                  • 297
                  #563
                  If the spark plugs and injectors are firing u should be good. Fuel may be filling the rails but injectors are not spraying.
                  • Reyhan335
                    • Nov 2015
                    • 700
                    #564
                    But for all 8 injectors to not spray... Idk.
                    • Q8y_drifter
                      • Aug 2009
                      • 297
                      #565
                      Depends on what he means by spark and fuel. Hence my follow up q
                      • SteveO
                        • Jul 2015
                        • 20
                        #566
                        I think the next logical step would be able to pull the injectors still on the rail and have them sraying onto something and see if fuel is actually making it into the cylinder
                        • Reyhan335
                          • Nov 2015
                          • 700
                          #567
                          I just don't understand. All 8 were spraying fine a month ago.... Now neither would spray? I mean what are the odds of that after the motor has been out for a year and some change that the injectors fail now.
                          • Nick_08
                            • 165
                            #568
                            checked fuel. yes
                            i'm shocked too man
                            Reyhan you said you checked fuel. So honestly if you are sure you have spark...just spray some damn starting fluid in the intake and see if it fires. If it does you have no fuel....
                            -Nick
                            • delamaize
                              • Nov 2013
                              • 1465
                              #569
                              Do you have a stock ECU still? If you do, plug that in and see if it will start. If it don't start, then computer is the issue.
                              Dumpster Fire Pilot
                              • Reyhan335
                                • Nov 2015
                                • 700
                                #570
                                No I don't have the computer :/ I just went ahead and sent it to Texas so they can try it on their cars.
