Im going to start putting more detail in this post for some record keeping, and shorten my original build thread. Browse on through to see the action on my car pre-swap.
http://www.r3vlimited.com/board/showthread.php?t=358716
'88 SETA, made 140hp/150ftlb on the dyno. M20 has been knocking a little when cold, but its survived ~10 track days.
Ready for some power.
M60b40 from a '95 740iL. 118k miles, looks clean. Nikasil, but leak down passed so I'm going for it.
Valves look good
Injectors are nasty, got them rebuilt by MEPEH. This is my second time using them, I highly recommend, lit af service.
Most pictures ive seen didnt have this insulation garbage. Ended up gluing itself to a water pipe.
Gross
Valley pan is super clean
This is why you replace everything. All 4 knock sensors were like this.
All the bolts for the throttle body were seized. Vice grips and a grinder get them off, i replaced them with same length hex socket head cap screws.
I bought this motor from someone who had a shop refresh the motor, but then had to stop the swap. The shop liked silicone. No gasket on this BRAND NEW WATER PUMP, just silicone. Didnt replace the water pipe o rings either, just added some silicone.
Gunk. All 3 cases were like this.
Guides and chain looked fine. So I will be replacing them
Jesus bolt took 10ft of pipe, the crank holder tool, and 20min of heat on the bolt head.
Cases finally off
Cases cleaned off by hand with a brush and gods fluid, brake clean. Still got some really hard deposits.
Parts all the time
Valves look good
Gross
Cases finally off
Parts all the time
