V8 Brake Booster Relocation Kit
  • AWDBOB
    hooptie connoisseur
    • Aug 2013
    • 4490
    v8booster by Bobbie Morrone, on Flickr
    v8 booster relo by Bobbie Morrone, on Flickr
    v8 booster2 by Bobbie Morrone, on Flickr
    • judgefargo
      • Mar 2018
      • 22
      Thanks mate.
      Originally posted by AWDBOB
      • Elysian
        • 674
        I ordered a kit today.
        • White325is
          • Oct 2006
          • 5947
          I made all of my own mounts. I just had to cock the one firewall bracket to the side.
          • Elysian
            • 674
            That truck-bed liner or whatever it is coating under the hood looks awesome. Is your motor mounted directly to the chassis?
            • White325is
              • Oct 2006
              • 5947
              It is. Its a LS1 swap. I will post some more photos in a build thread once its complete. Should be a week or so.
              • Elysian
                • 674
                Nice, can't wait to see it, looks super clean just from those shots.
                • White325is
                  • Oct 2006
                  • 5947
                  Its a lot further along then this. But this is all I have in my phone right now.
                  • JGood
                    • Jan 2004
                    • 7959
                    That looks really good. Too bad DOHC v8's occupy the space where that firewall bracket mounts in the factory location. Modifying the pedal bracket assembly correctly to move that thing to the other side of the brake pedal is the hardest part of the damn swap.
                    e30 restoration and V8 swap
                    24 Hours of Lemons e30 build
                    • White325is
                      • Oct 2006
                      • 5947
                      Yeah, I just rotated the bracket and drilled 4 new holes. bolted it in with a new seal. I did shorten the lever on the outside to line up better with the booster though.
                      • Pootis
                        • 636
                        What headers are you running if you don't me asking
                        1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
                        COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
                        • White325is
                          • Oct 2006
                          • 5947
                          I made them, along with all of the mounts.
                          • Elysian
                            • 674
                            Started the install. The kit doesn't come with the clevis, so you'll need to buy one, which isn't mentioned in the install guide. They're cheap on ECS, with all the parts I had to buy to finish this out I was over the threshold for free shipping. ECS carries the T fitting, as well as the extensions brake line.
                            • dmjensen
                              • Jan 2011
                              • 805
                              On average how much is this set up costing VS. doing the wilwood/ Tilton setup?
                              I’m going to be using 335i F30 sport brake calipers and I’m wondering which way would be my most cost affective and best route
                              • Elysian
                                • 674
                                I got the E34 setup for $400,might be able to find it cheaper, might cost more. I'm about $550 in with the 300mm.de kit. Can probably make the stock components work, but that takes more time.
