E30 diff upgrade
  • Leonstt
    • Feb 2019
    • 81
    E30 diff upgrade
    Hi guys
    I have a question regarding diff ratio of my E30. The setup I'm running curently is M52B28 engine combined with E36 323i tranny and inthe back I'm using E30 M10 diff with 3.64:1 ratio. I'm not too happy with this Drivetrain setup because the gearing is way too short for my liking. What setup can I use to get longer gearing to make it a little more bearable on the highway? I have a budget, so i cannot go for some fancy racing diffs
    Thanks
  • 82eye
    • Jan 2009
    • 2108
    i think etas run 2:92.
    • Northern
      I like cupcakes & sh!tboxes
      • 5284
      ^ List of what cars came with which diffs.
      You want something 2.93~3.25 to be close to stock. Which of these are actually available to you will depend on your country,
      Originally posted by priapism
      Originally posted by shameson
      • 82eye
        • Jan 2009
        • 2108
        if you know what you are doing it is possible to swap gear sets in the case. the m10 would be a small case 168mm diff. something to keep in mind if you ultimately swap crown and pinion gear sets. not sure i would go to the bother unless the diff had an ls unit though.
        • TobyB
          • 5297
          The small case can't go much lower- 3.45 from a manual E36 318's the practical limit. That case will bolt in, if you can find one from a 318ti
          The mid case had 2.7x in early manual etas, 2.93 in later etas,
          and the E36 can give you a 3.15 gearset if you
          wanted to split the difference. but you'd have to assemble that, and make
          sure you used a carrier from a 3.15 and higher e30, as the 2.93 carrier has different spacing.
          t
          2.93 and fine with that, because 1st is pretty low already.
