Stripped threads for coolant block on throttle housing
  • rhockyrhodes
    • Oct 2024
    • 3
    Advice needed... While replacing the gasket for the coolant block I stripped the threads for one of the screws. Do I need to buy whole new throttle body or can I repair this? Is epoxy or Heli-coil an option?
    (photo is not mine, but you get the idea)
    Thanks,
    -Jesse
  • 82eye
    • Jan 2009
    • 2108
    try tap it first. it's metric, so if you have to drill the rest of the threads out you can go to an sae a hair size larger and get a bolt for that.
    edit : epoxy etc won't cut it in that app. not sure you can get a heli small enough to work.
    • moatilliatta
      • 6158
      Time sert could work
      @Zakspeed_US
      • rhockyrhodes
        • Oct 2024
        • 3
        It looks like they have inserts small enough. If that doesn't work I'll try and tap it. Thanks!
        • MrBurgundy
          R3V Degenerate
          • Mar 2012
          • 5604
          Happened to me and I just went with the next closest size, which was actually a standard size. Better than dealing with any inserts IMO.
          • ehrawn
            • Aug 2023
            • 235
            Keenserts or similar are the best method. We sometimes spec them in softer material like aluminum from the manufacturer as a preventative measure.
            • cory58
              • 1021
              Never knew about Keenserts. Interesting design. Why are they better than Helicoil/Timesert in soft material?
              1992 325i Cabrio
              1988 320i Touring
              2000 M5
              1977 530i
              2015 328i - Euro Delivery/Performance Center Delivery
              BMWCCA
              E30CCA
