How to properly delete the plastic fuel expansion tank lines?
  • eight-0-eight
    • Aug 2020
    • 37
    Hi all,
    So I had to replace the thicker braided line that goes from the gas tank to the evap tank in the right rear tire well.
    While doing so, the only way I could get that thicker hose through the conduit was to remove the 2 smaller plastic lines that also connect to the evap tank.
    I've tried so many different ways of trying to fish all 3 through, but it's just not happening (unless anyone has some ideas...) and so I saw some old posts about deleting the evap tank as a whole and connecting the two lines at the top of the gas tank but it wasn't exactly clear to me exactly how and what to block off, vent, etc.
    What I want to achieve is keeping the thicker braided line but delete the smaller plastic lines as I just can't get those fished through so if anyone has suggestions on that, I would appreciate it!
    At the gas tank:
    - Connection to large braided line --> goes to T
    - connection to smaller plastic line --> goes to smaller line on expansion tank
    - connection to larger plastic line --> goes to larger line on expansion tank
    at the expansion tank:
    - connection to large plastic line
    - connection to T
    at the filler:
    - connection to T (with larger part connecting to braided and smaller connecting to expansion tank)
    What do I cap, loop, vent to get rid of these stupid plastic lines ?
  • TobyB
    • 5293
    You can't just e- tape the 3 together and pull them as one?
    Stagger the 2 smaller lines behind the big one by an inch each,
    and wrap the whole thing. Then lube it up with something like
    pulling lube or dish detergent. . .
    One of the nice things about the E30 is that it has a modern evap
    system, and doesn't smell like fuel all the time like a 2002 or E21 does...
    t
    • Panici
      • Dec 2009
      • 2569
      Might you be referring to my thread from 2019?
      That is a valid point, and I can confirm that my car does not smell like gas with the above setup.
      I left the charcoal canister and purge valve in place.
      • eight-0-eight
        • Aug 2020
        • 37
        t
        Thanks for the suggestion, yeah I tried so many combinations of that. staggering, taping in different orientations. I fished a string through there and tied it to the hose and tried to route it while my wife was pulling from inside...still couldnt get it.
        Yes! Thanks for the write up. I was getting confused about what was getting capped on the T portion that goes to the expansion tank. I've re-read a few times and I think I understand it now. Panici have you had any issues with this setup besides the slight concern about filling it too much and having a bit of fuel go to the charcoal?
        Tonight, I finally got the smaller plastic line through along with the large braided line, so I "deleted" the larger plastic one.
        - I capped the larger plastic hose at the top of the fuel tank (Which I think will just allow that side of the tank to vent to the charcoal up front, that I recently refreshed.)
        - I also put a small breather filter on the top of the expansion tank (as was showed by someone else in that 👆thread, where the other end of the larger plastic hose would have gone.
        - then left the smaller plastic hose connected to the bottom of the expansion tank to the fuel tank
        - everything else was as normal (large braided to the T, which goes to the filler neck and smaller hose to the expansion tank.
        That should work, right? The driver side should vent to charcoal and the venting from the filler & right side will go to the expansion...with smaller line feeding back to the tank.
        • Panici
          • Dec 2009
          • 2569
          Zero issues.
          Granted I don't park outside in the sun that often, which would be a good test for the system.
          Shouldn't need a breather if you hook it up like my writeup. The gas tank "breathes" (in and out) through the charcoal canister, and then when the purge valve fires off, the charcoal is purged of fuel vapor to be used again.
          • eight-0-eight
            • Aug 2020
            • 37
            Originally posted by Panici
            Zero issues.
            Mine stays in a garage as well. Okay well I will see how this goes but if I start to get fumes, I'll likely just disconnect the smaller line as well and loop them above the gas tank, and cap the smaller line at the T fitting by the filler, as you did.
            I suppose the only concern with your setup is that if somehow the line between the tank and the charcoal canister gets clogged and you're out in sun that it would build pressure, right? Do you have a vented gas cap as well?
            • Panici
              • Dec 2009
              • 2569
              My concern would be, parked in the sun with a full tank.
              Heated/pressurized fuel wouldn't have the expansion tank to flow into, and would instead be pushed into the charcoal canister.
              From what I've read liquid fuel will damage a charcoal canister.
              No vented gas cap on my car.
              • digger
                • Nov 2005
                • 6196
                shows the use of a smaller 1/12" (instead of 14x20) non braided hose which appear to have made it easier to slide due to physical size and less friction
