Diff clucking on take off
  • zaq123
    • Jul 2016
    • 1514
    So I have this really slight metallic clenching noise on the driver's side. Sounds almost like axle shaft splines are hitting splines in the hub on take off (common VW problem) but it is not. It appears that the clunk comes from the differential ourput flange. And not from the rotational motion but from moving the flange in and out (thrust load, not rotational load). I did replace sealed on the axle and that was about it. What exactly is making that clunk? It's louder on the drivers side and more muffled on the passenger side. Basically pull on the flange with in/out motion and you will hear what I'm talking about. Any ideas? IIt is LSD diff from very low mileage Z3 but it doesn't sound like M-clunk to me
  • zaq123
    • Jul 2016
    • 1514
    Post Edits don't work on the forum again.
    to add:IIt is LSD diff from very low mileage Z3 but it doesn't sound like M-clunk issue to me that's common on M models of E46, E90 etc cars
    • zaq123
      • Jul 2016
      • 1514
      link to the video. Again it is not up/down play clunk or the axleshaft clunk. Output shaft clunk in the thrust (in/out) motion only.. Only audible on take off from a stop.
      https://www.dropbox.com/scl/fi/5xxb9pyx598xfsimxjcjb/diff.mov?rlkey=w1nok2xcn038vx6eccj4w4kxv&st=0e5x5a eg&dl=0
      • 82eye
        • Jan 2009
        • 2024
        there is a little play there but not all that much. i'm not sure that amount of play is outside of normal. i've rebuilt diffs, and axles, and had others on and off a car before but never noticed any unusual noises.
        • zaq123
          • Jul 2016
          • 1514
          new C clip was used. Right flange has that play too but not making that metal on metal noise when I slide it in/out.
          • 82eye
            • Jan 2009
            • 2024
            think a clip might have let go?
            • digger
              • Nov 2005
              • 6125
              i had what might be a somewhat similar issue when i change my e30 188 diff, the output flange wasn't properly seated so would pop out i just has to bang in it fully home
              • 82eye
                • Jan 2009
                • 2024
                probably this ^
