MarkD M42 Chip installed
  • peteM3power
    • 450
    #61
    Originally posted by Rob
    thanks mark. I'll give it a try later this week. will report back in this thread...
    Sounds good Rob. Can't wait to see the dyno results.
    Pete
    • MarkD
      • Sep 2004
      • 486
      #62
      Pete
      The dyno results may not be as impressive as the chip is in real life. The main reason is that it takes at least 100 miles of driving for the DME to adapt once the power is removed from it. It's best not to perforn a dyno run right after changing a chip.
      MarkD
      URL: www.dsylva-tech.ca
      • Rob
        • 8166
        #63
        I cant think of another way to have a truly back to back comparison though, I plan on doing a few 'drag runs' and maybe some top speed pulls on the dyno before I actually make the pulls with the new chip. Dynoing with the stock chip, then unhooking the car and driving around for a while isnt ideal in the interest of time
        BEERTECH
        • peteM3power
          • 450
          #64
          What ever you get, I'm interested in seeing it anyway Rob. Mark, fair point but don't worry, I am still interested in this chip :D !
          Pete
          • rwh11385
            lance_entities
            • 18403
            #65
            MarkD
            What about doing what I am planning on doing?
            Test the MarkD chip first, as it would have already been adapted, then put the stock chip in?
            You wouldn't have to have any down time.
            Well, I might have to run it to redline up there, but not necessarily do a recorded "pull" to get the ECU to reduce the duty cycles of my 19lb injectors.
            But unless I'm overlooking something, I don't see why you cannot run the modded chip first, then go to stock. I'm imagining the stock chip should behave as stock when the power is reset......?
            • Rob
              • 8166
              #66
              that method works robert
              BEERTECH
              • nickmp0wer
                • 1427
                #67
                tried the 92 octane yet?
                • Anthrsckmnd
                  • Aug 2004
                  • 241
                  #68
                  I'm also really interested in a 92 octane test as that is the highest available in Hawaii. If it runs well, definately count me in for a chip.
                  • Digitalwave
                    is a poseur
                    • 6293
                    #69
                    MarkD
                    The ECU has to adjust to a stock chip as well.
                    RISING EDGE
                    • theberglar
                      • 143
                      #70
                      True. I have to remove and recharge my battery every time I come back to my car ('89 325i) from school. The idle is rough every time for the first ~50 or so miles.
                      • nickmp0wer
                        • 1427
                        #71
                        howed the 92 octane work out?
                        • pig4bill
                          • Sep 2004
                          • 122
                          #72
                          Get one of those solar powered trickle chargers. It sits on the dash and plugs into the lighter.
                          • nickmp0wer
                            • 1427
                            #73
                            cough 92 octane cough
                            • Erick
                              Official R3V Drifter
                              • 11169
                              #74
                              Hey Rob, how does it feel to have the extra 800rpms on a turn?
                              ..::Support FullOpp::..
                              FullOpp Stickers for sale!
                              Feedback Thread
                              • royalflush313
                                • Mar 2004
                                • 2070
                                #75
                                any updates?
                                ~ Go Canucks Go! ~
