Mobil 1 V-twin 20w50 oil
  • JGood
    • Jan 2004
    • 7959
    Anyone use this? I came across a large quantity for $1.85/qt, and am wondering if it is OK to use in my m20 track car. I know it's motorcycle oil, but from what I understand it's high in ZDDP.
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
  • M-technik-3
    • 18946
    Valvolene VR1 is a high ZDDP oil and reasonable in price.
    • JGood
      • Jan 2004
      • 7959
      It's also $4.50+ /qt, which is 2.5x the cost. I found 37 gallons of this stuff (!) for $275...
      Normally I run non-synthetic, but this is even cheaper then the cheapest non-syn's... I can't turn it down, unless someone can tell me it's specifically not good for our motors. But all I can find so far is that a lot of air-cooled Porsche and motorcycle guys use this oil, and it's around $8/qt. It's also apparently one of the very few true group IV oils left.
      • M-technik-3
        • 18946
        Not here, guess I have a cheap autozone it's $2.57 a quart. Look for the API seals on the back and see if it has the same car seal or call BlackStone labs or another oil analysis company and ask the question.
        • JGood
          • Jan 2004
          • 7959
          If I could get any oil for $2.57/qt at autozone, I would. Even the regular Valvoline/Castrol/Pennzoil is $4+.
          VR1 20w50, $4.29 online:
          http://www.autozone.com/autozone/cat...Name=Valvoline
          • M-technik-3
            • 18946
            Well I'm happy. Sorry you getting screwed out that way, what about a truck based oil like Shell Rotella?
              • 34847
              rotella doesn't have great ZDDP comparatively
              Mobil 1 15w50 and VR1 are both good. I thought I heard that stuff mentioned in another thread. at that price I'd buy it and do an oil analysis.
              • JGood
                • Jan 2004
                • 7959
                Yeah, it's reasonably priced, just nowhere near $1.87. And it's not a group IV full synthetic like the $8/qt Mobil is.
                I told the guy I'll take it, so we'll see what happens.
                • FredK
                  • 14763
                  That's insanely cheap, because my friend filled his motorcycle with 2 quarts and it costed him $10/qt at Advance Auto Parts.
                  V-twin has an insane amount of zinc in it. I doubt it'd really help or hurt you, so synthetic oil for $1.85/qt is a great deal.
                  • M-technik-3
                    • 18946
                    Wasn't sure as he mentioned he would buy any conventional oils if they were cheap.
                    • TOM1911
                      • Dec 2009
                      • 51
                      I don't know for sure but, ZDDP oils can be detrimental to automobiles with catalytics and I was told not to use them in modern cars.
                      • M-technik-3
                        • 18946
                        M20's and S14's are not modern engines, the ZDDP is a wear additive helps older cars. Hence the phase out in oils. Another way of killing off older cars.
                          • 34847
                          supposedly, but A) E30s aren't modern and B) the actual effects on a cat isn't certain. Consider how long E30 cats last - a couple hundred thousand miles, easy.
                          • JGood
                            • Jan 2004
                            • 7959
                            Same things I've heard. I have $50 magnaflow universal cats on my cars anyway. If they last 3 years, I'll be happy.
                              • 34847
                              yeah, those magnaflow cats aren't so good. 3 years would be a miracle.
