I hate wiring, Help me 4x4 my IX! No Spark, FML
  • accident
    • 7303
    is your check engine light coming on with the key in run? If not, the DME either isnt getting power or is broken
    Moral of this story?
    • JakeP
      • 315
      Yes, check engine light is flashing with the key on.
      • dark89e30
        • 263
        Do you have a check engine light with the key turned to run?
        • dark89e30
          • 263
          Flashing not good.
            • 34844
            the check engine light is flashing, or the check light is flashing? the check engine light should be solid.
            • JakeP
              • 315
              Hmmm, now I'm not sure. I'll drive over there in a bit and take a look.
              • accident
                • 7303
                the CEL will actually say CHECK ENGINE, and it is not the light that flashes saying CHECK.
                • JakeP
                  • 315
                  I'm pretty sure it was a flashing CHECK light. I thought it was odd that it didn't say ENGINE.
                  • accident
                    • 7303
                    yeah, that's referencing the check panel above the rearview mirror. assuming none of the other lights are on, the brake light should go away the first time you hit the brake pedal, and take the CHECK light with it. Also pushing the CHECK button on the panel will stop the flashing as well.
                    • JakeP
                      • 315
                      e30>me
                      Be back on after a bit guys. Thanks for the suggestions so far!
                      • accident
                        • 7303
                        if i get my paycheck today i'll be more than happy to drive out there and try to hammer this out with you.
                        • E30Nova
                          • 1546
                          This sounds like you're looking at the flashing "check" light for the overhead check panel.
                          Check engine light should be solid in the bottom left corner of the cluster, right around the foglight symbol.
                          EDIT: Nevermind, everyone else already said that lol.
                          But just throwing it out there, the relays should all be fine. The harness and relays were taken from my car, which ran flawlessly up until I wrecked it. I suck at electrical work, though, so I can't really help diagnose.
                          Matt
                          I pack my CD player with asbestos. Those mother fuckers pay dearly for stealing my shit.
                          Originally posted by kronus
                          try whacking parts of the motor with a wrench while yelling "YOU WANT SUMMA DIS? HUH?"
                          This is like a reverse build thread; it starts out nice and gets shitty.
                          • JakeP
                            • 315
                            Checked and swapped Main Relay. No change. Still not getting power to the coil.
                            Pin 27 is still dead. We have ground on all the pins listed in the first post. IIRC, 2,14,19,2...
                            • dark89e30
                              • 263
                              Just because you have continuity to ground does not mean you have good ground. You'd have to measure voltage drop under load to determine that. If your coil is not getting batt positive, its prob a 90% chance the ignition switch is the problem, just based on that. Pin 18 is hot at all times, pin 27 is the dme turn on lead and splits to the coil AFTER the ignition switch. Go buy a NEW ignition switch.
                              • E30Nova
                                • 1546
                                Hey Jake, I'll try and pull my ignition switch so when you come by Friday you can grab that too. Unless you have a spare on hand already.
                                Matt
