adjusting valves
Some VAFM equipped fuel systems (Toyota for one) run the fuel pump when the AFM flap moves due to engine vacuum. It wouldn't work with the ignition off though so maybe that isnt what he was getting at. I think Motronic runs the fuel pump when it sees a crank position sensor signal, I could be wrong though.Last edited by Sagaris; 10-15-2011, 04:01 AM.Comment
I think some of these mooks are talking about adjusting the valves with the car running, but I have no clue how you'd go about adjusting an eccentric-style system while the car is on.Originally posted by george gravesIf people keep quoting me in their sig, I'm going to burn this motherfucker down.Comment
E30s (except the 318is) only run the fuel pump when the ECU gets an RPM signal.Some VAFM equipped fuel systems (Toyota for one) run the fuel pump when the AFM flap moves due to engine vacuum. It wouldn't work with the ignition off though so maybe that isnt what he was getting at. I think Motronic runs the fuel pump when it sees a crank position sensor, signal could be wrong though.Comment
i was busting nando's chops for saying that "the lash gets bigger when the engine warms up." I don't think he meant what he wrote, but you never know. He hasn't responded.sigpicComment
