very noob question.
  • immajackuup
    • Dec 2010
    • 1132
    very noob question.
    Is bmw e30 battery the same as civic battery?? because i need a new battery before i sell my civic to some1.
  • Ryann
    • 3350
    Originally posted by Ryann
    r3v is going to light you up.
    • immajackuup
      • Dec 2010
      • 1132
      for what?
        • 37833
        No.
        It's spelled "someone" not "some1".
        Grover Beach, California
        BimmerHeads.com
        • immajackuup
          • Dec 2010
          • 1132
          Originally posted by MR 325
          No.
          i know,like to have it short lol but thanks for your help.
          • GunMetalGrey
            • Dec 2010
            • 1499
            Car batteries are all the same, pretty much. It will work.
            • Dj Buttchug
              • Jun 2010
              • 7688
              civic batteries are usually lighter because they are small
              Turbo M42 Build Thread :Here
              Ig:ryno_pzk
              I like the tuna here.
              Originally posted by lambo
              • matias88e30
                • Dec 2009
                • 1110
                keep it, if doesnt work get one new
                no more boosted m20, 91 318i...
                • hotballs
                  • 1155
                  So are U going 2 sell your civic with a bad battery?
                  • jasonsnoddy
                    • 1900
                    Wat iz g0in un hur
                    Originally posted by stewie30luvr
                    ooo cause i was fixing my chain tensioner and there was a black widow on the radiator so i killed it
                    Originally posted by JakeP
                    with a coathanger
                    • AndrewBird
                      The Mad Scientist
                      • 11898
                      E30's use batteries with the terminals flipped from standard. So if you do use your Civic battery (assuming it is standard style), you will have to get a longer ground cable to make it work.
                      • Ryann
                        • 3350
                        • immajackuup
                          • Dec 2010
                          • 1132
                          thinking the same.
                          no,I'm not a shady type of person. Battery is only two years old which mean it shouldn't be bad. Think of letting autozone recharge the battery or test it to see is a bad battery. Battery died twice because alarm keep going off while I'm not home.
                          • immajackuup
                            • Dec 2010
                            • 1132
                            • McGyver
                              • 4636
                              1)jump the car
                              2)drive to auto zone
                              3)politely, using proper english, ask them to test your battery and alternator
                              4) a. if both are good, drive it around until the battery is charged and then remove the crappy alarm.
                              b. if the battery is bad, replace it and remove crappy alarm
                              c. if the alternator is bad, replace it and remove crappy alarm
                              5)stop asking stupid common sense questions
