m30 afm + 19lb injectors =afpr needed???
  • madjurgen
    • May 2005
    • 1203
    Thinking about the m30 afm swap. I know bigger 19lb mustang injectors are necessary but is it also necessary to install an afpr or will the ecu just teach the injectors??
    As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
    You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
  • cahomey
    • Mar 2004
    • 1201
    The ecu teachers those little waffleswaffleswaffleswaffless like a nun armed with a ruler.
    "It's like a koala bear crapped a rainbow in my brain."
    R.I.P. Harry Goz aka. Captain Murphy
    "My ride, My ride, she don't beg, steal, cheat, or lie,
    My ride, My ride, and our relationship is classified."
    • madjurgen
      • May 2005
      • 1203
      So is that a no?
      • PeaveyBassist
        • Sep 2004
        • 3511
        Correct. The ECU will learn the new injectors just fine.
        Will
        RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
        Welcome e30 (brilliantrot '90 325is) 12/23/06
        DaveCN = Old Man
        My signature picture was taken by ME! Not by anyone else!
        If people keep quoting me in their sig, I'm going to burn this motherfucker down.
        • madjurgen
          • May 2005
          • 1203
          best/cheapest place to buy 19lb injectors?
          • NORCAL/E30
            • Dec 2004
            • 258
            classified section :D
            ABE
              • 37833
              I had no issues without a AFPR
              Grover Beach, California
              BimmerHeads.com
              • kowalski
                • Jan 2005
                • 1791
                i installed them on my M42 2 weeks ago not a problem, runs like a top and spunky too :shock:
                • rwh11385
                  lance_entities
                  • 18403
                  19lb = mustang 5.0. bosch.
                  17lb = m50/s50 injectors. type II = four pintle = good.
                  either gravy
                  • kowalski
                    • Jan 2005
                    • 1791
                    you can get the 19's in 4 pintle as well
                    • NC325iC
                      • Mar 2004
                      • 6565
                      then why the hell does my shit smell rich?
                      and not have a cold idle what is goin wrong here?
                      • nickmp0wer
                        • 1427
                        unplug the battery for a while then it should reset the ecu then try it again
                        • Digitalwave
                          is a poseur
                          • 6299
                          I personally would not perform those mods without an AFPR and some dyno time afterwards.
                          RISING EDGE
                            • 34844
                            they're like $50 and it took me an hour to swap them in 2 years ago. why not?
                            • gstuning
                              • 833
                              Relying on the O2 to help you with the injectors it totally the incorrect way to do things,
                              you have to have a mixture metering device to know what is actually going on in your exhaust, not just guessing = wideband
                              Gunni
                              @ Prodrive / Aston Martin Racing
