What is your full tank range?
  • bernzpeed
    • 3917
    I am noticing something fishy with my 89 325i. I am only getting about 200 miles on a full tank of gas according to my odo and OBC?
    What is yours and what could be my problem?
    89 E30 S52
    Transaction Feedback.
  • MrSlacker
    • 2494
    Is it city or highway driving? How many gallons do you fill up from empty to full? Could be that your "empty" is not really empty and you still have plenty of gas left.
    My Seller/Buyer Feedback
    Performance Aftermarket Parts & Accessories
    • devon.818
      • Feb 2011
      • 2937
      atleast your odo works!
      my obc spaz's out and my odo doesn't spin...i think i get around 20mpg...mainly cause i gun it at EVERY stoplight and the 4.10lsd does not help on highway lol.
      • StereoInstaller1
        GAS
        • 22679
        I typically got about 250ish mixed, as much as 300 road tripping.
        Closing SOON!
        Thanks for 10 years of fun!
        • bernzpeed
          • 3917
          well, initially, i did an engine swap and i swap the speedo cluster from my 87 to my 89 325i. then, the fuel gauge was acting up and saying it was empty but there was still half a tank of gas in it. then one time i filled up, the pump stopped and gauge shows, half a tank. (OBC was not set yet at this point) After a few fill ups, the gauge shows full now, but goes down quite faster than normal. My odo says 135 and my OBO range says 65 to 70 miles left on separate occasions.
          This is from driving it on cruise control within 65mph speed limit.
          What could it be?
          89 E30 S52
          • E30Gus
            • Jun 2008
            • 781
            ^ This. There is a difference between early and late (I don't know the cut off years) fuel gauges late=2 senders, early = 1 sender.
            I would check that first to make sure they are compatible.
            • gath
              • 577
              The highest I got was 350 miles on a full tank, but normally i get 330 on a full tank.
              '89 325is, no mods only a chip.. funny coz I know I run rich but haven't been able to diagnose the problem. average 23 to 25 mpg.
              • nomansland92
                • 1657
                I have 3.91s and i estimated about 200 to 220. I usaully drive pretty easy too so i think I should get a lot better
                IX being restored here
                Ix turbo build here
                • bernzpeed
                  • 3917
                  So I just filled up another full tank of gas since my needle was on empty since 2 days ago. Pump stopped a little over 7 gallons this time. Last time it was a little over 8 gallons. My fuel log says I used up 19.1 mpg.
                  Should I be replacing the fuel sender or the fuel gauge?
                  89 E30 S52
                  • E30SPDFRK
                    • 5716
                    Replace the gauge with one from a late model, you should be able to put over 13 gallons in when it's empty.
                    Byron
                    Leichtbau
                    • jasonsnoddy
                      • 1900
                      mostly freeway i get 360, mostly city is around 280, or 300 if im careful. "I" car with 3.73
                      Originally posted by stewie30luvr
                      ooo cause i was fixing my chain tensioner and there was a black widow on the radiator so i killed it
                      Originally posted by JakeP
                      with a coathanger
                      • gath
                        • 577
                        I have a 5 speed with 4.10 LSD.. I think if I had a diff with a lower ratio I should be able to get a better MPG.
                          • 34844
                          I really don't think the diff makes a huge difference, I got 21-26 (300-350 miles or so) with the automatic and 4.10s, it only dropped a little with the 5 speed and stroker. Nowadays it's between 250-350 miles per tank.
                          • b*saint
                            • 3794
                            Ma che cazzo state dicendo? :|
                            • poopin04
                              • Jul 2010
                              • 1396
                              300+ miles?!? Yup there is something serious fucking wrong with my E30. HELL I got an ETA and I don't get those miles. I think it might have to do something with my gauges, as it was swamped out by the PO with an i cluster. hmmmm.....
                              Click here to leave me feedback on our transactions. :p
