Remove subframe the subframe for oil pan gasket?
  • RefinedThinking
    • Sep 2011
    • 119
    So the general consensus is loosen the motor mounts a little and jack it up by the a/c bracket? Any recommendations on the best gaskets?
    • Dj Buttchug
      • Jun 2010
      • 7677
      not victor reinz
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • fatsooo
        • 312
        Originally posted by Dj Buttchug
        not victor reinz
        this.
        i believe i have goetz in mine...just look around to the beloved suppliers and you can find em among others....
        • pandaboo911
          • 2070
          Originally posted by bernzpeed
          what? the oil pump is in the way, you can't just slide it out.
          i had to unbolt motor mounts, raise the engine, unbolted the pan and unbolted the oil pump as well to both slide it out.
          bell housing is pita
          This is what I did. Dropped the pump into the pan and slid it out. The only thing I found difficult was re-fitting the shaft that drives the pump with about 2 inches of clearance between the pan and block.
          With a friend and some beers this job is a breeze.
