Remove subframe the subframe for oil pan gasket?
  • RefinedThinking
    • Sep 2011
    • 119
    Any one have any thoughts on this vs hoisting the engine and whatever else? I don't have an effective way to really hoist the engine and at first thought removing the subframe would be the way to go, any experience on this?
  • FunfGan
    • Jan 2011
    • 4958
    You realize the engine is bolted to the subframe, correct?
    Edit: I am assuming you have a 24v.
    Go here be happy!
    Ratchet Garage e30 V8 build.
    • Dj Buttchug
      • Jun 2010
      • 7688
      what engine....?
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • Massimo
        • Jan 2008
        • 3207
        If you have M42 it can be done without removing engine.
        • RefinedThinking
          • Sep 2011
          • 119
          M20, sorry.
          • Kershaw
            • 11822
            its a pain, but you dont need to do anything. just unbolt the pan. that's how i did it. slide it out from on top of the subframe.
            a bit of finagling.
            AWD > RWD
            • RefinedThinking
              • Sep 2011
              • 119
              a bit of finagling.
              good to know, thank you.
              • iwantspeed
                • 3164
                you can also loosen the motor mounts
                jack up the engine by the ac bracket
                remove the oil pan bolts
                remove the 2 bolts for the oil pump pick up and the pan will slide out.
                Project
                Parts for Sale
                Feedback
                YouTube Channel
                • Kershaw
                  • 11822
                  that's a pretty good idea. i bet it makes it a lot easier to remove.
                  AWD > RWD
                  • slammin.e28
                    שמע ישראל
                    • 12054
                    • gtdragon980
                      • Jun 2008
                      • 1808
                      I agree with iwantspeed, just lift the engine up a tad and go to town on the oil pan bolts. It's not tooo hard, just getting around the oil pump is a hassle with the gasket on. Make sure to use some gasket adhesive so the gasket does not move around when you are trying to put it back on. Otherwise, its a fairly simple job.
                      FREE BITCOINS!! http://qoinpro.com/71690d1639966bfbf223bf16538cec21
                      Originally posted by scabzzzz
                      I stand up, pull my dick out, and asked my gf to give me some noggin... Well, she starts laughing at me and I freaked out and ran off and locked myself in a bedroom.
                      1989 325i - Project/weekend driver
                      2002 325i - DD
                      2005 Suzuki SV650 - Toy
                      • Oly_Schmidt
                        • 111
                        Just did two of these. The pan comes out by just loosening the the right motor mount and lifting the engine an inch or two. I didn't see a way to get it out without removing the oil pump while it's still in the (unbolted) pan. It's a pain but can be done.
                        As said earlier, allow the new gasket fully set up, cuz you will be banging on it to get the pan back in.
                        • nebulous123
                          • Jun 2011
                          • 923
                          ^this...but I took off the bell-housing cover undid as many bolts as I could on the pan. took off the motor mount bolts and jacked up the motor from the bell-housing took off the bolts for the oil pump pickup and it slid out.
                          with the jack over by the bell-housing it makes it easier to move around and get the pan out. imo
                          '84 325e - "Elizabeth"
                          '87 325e (SHELL) - "Sleeping Beauty" - COMPLETE PROJECT PART-OUT - S54, 5-LUG, and MORE
                          • bernzpeed
                            • 3917
                            a bit of finagling.
                            what? the oil pump is in the way, you can't just slide it out.
                            i had to unbolt motor mounts, raise the engine, unbolted the pan and unbolted the oil pump as well to both slide it out.
                            bell housing is pita
                            89 E30 S52
                            Transaction Feedback.
                            • Red88
                              • Nov 2008
                              • 1161
                              I've taken one off with finagling but I had to raise the engine to put the pan back on with the new gasket
                              Have you made a purchase from www.blunttech.com recently?
                              sigpic<< wrecked
