Skid plates for the E30.
  • Joe318is
    • Sep 2005
    • 6451
    #46
    Originally posted by parkerbink
    I submit the oil pan being the lowest point on the car is a severe design flaw.
    At stock height it is much too close. When you add to the equation lowering the car it is much too close. Unless of course you can warp physics and cause a car to have no downward motion in it's suspension.
    YEAH!!! Why didnt they put the oil pan where the battery used to be? theres plenty of room there!
    Originally posted by vlad
    • nefarious7907
      • Jan 2005
      • 1170
      #47
      How low do the M roadster diff covers hang down?
      http://www.cardomain.com/ride/657387
      • SykoBMW
        • 1065
        #48
        Anyone have the stock skid plate PN?
        • Fidhle007
          I can fly, motherfucker
          • Oct 2005
          • 7209
          #49
          I've had one oil pan issue but that was an over-the-river-and-through-the-woods type deal. Actually through a snow bank and into a tree... (Not my fault) That was with the stock suspension, I've since lowered the car about 2" and have had no problems. I usually bash the shit out of my front lip long before I ever get to the oil pan... My question to the rest of you guys who don't have scraping issues is how do you avoid smashing body kit bits? I was epoxying for hours tonight...:curse:
          '89 325is S50 Track Montser
          '04 X5 Daily/Tow Vehicle
          http://www.avarestoration.com
          http://www.myspace.com/brendanfiddle
          Click here if you want to be my zombie slave...
          http://www.youtube.com/user/Fidhle007
          • golde30
            • 11464
            #50
            my car isnt even THAT low, and my freshly powdercoated oil pan is all scraped to shit, even though i drive hella slow over bumps and what not.
            IG: @Baye30
            • rs4pro3
              • 5808
              #51
              My Oil pan is 3.5" off the ground and the M-cover is 5" off the ground
              85 325e 2.7 ITB'd stroker
              • DarkWing6
                • Apr 2004
                • 7144
                #52
                I'm right here with you. I have no lip on the front of my car right now cause I gotta repair it (judged a ramp into a parking lot to be a lot flatter than it really was). I didn't scrape it too bad, but one of the clips on the inside broke. The only reason I would put a skidplate on my oilpan is to be safe. Can someone explain how they craked their oilpan without messing up the body of their car?
                • parkerbink
                  • Jun 2004
                  • 10137
                  #53
                  As to not damaging the body, I had a cab front end that was much higher then my current is lip, hopefully I will escape Mexico with the lip intact.
                  oem skidplate pn's:
                  51 71 1 929 451 - non-M up to 9/87
                  51 71 1 971 001 - non-M from 9/87
                  51 71 1 961 905 - M3
                  51 71 1 943 101 - iX
                  kowalski can you post the dimensions of your skidplate?
                  • hamann318is
                    • 3382
                    #54
                    Originally posted by cgregory
                    +1
                    I'm slammed on GCs and the worst I've done is scrape the cat once in a parking garage.
                    I have picked up little pieces of fur from already flattened road kill though:(
                    I hit the cat if I bottom out. I've never hit the oil pan. Roads in Columbia suck ass though.
                    The BMW 318 is back. With a vengeance.
                    • nefarious7907
                      • Jan 2005
                      • 1170
                      #55
                      I have been looking at the pic on RealOEM and then looking at my car but where do the front and rear bolts, bolt to?
                      • parkerbink
                        • Jun 2004
                        • 10137
                        #56
                        kowalski can you post the dimensions of your skidplate please?
                        • kowalski
                          • Jan 2005
                          • 1791
                          #57
                          yeah, its dark right now, but tomorrow ill take some measurments and everything else.
                          PS: cut the drain hole for the oil longer as it tends to drip onto the skid plate and then it is really messy
                          • parkerbink
                            • Jun 2004
                            • 10137
                            #58
                            Muchas Gracias!
                            • Ryan Stewart
                              I Love Miatas
                              • 8978
                              #59
                              Same here except its the center resonator. My oilpan sits right with the suspension so I would have to do plowing into a bump at warp speed to fuck it up. Or I guess if you took tall speedbumps at a 45 degree angle the car could settle down between the front wheels and hit the pan.
                              My car isnt slammed though, only a 1.5" drop.
                              Im now E30less.
                              • parkerbink
                                • Jun 2004
                                • 10137
                                #60
                                I have no clue why but before the new front end when I went over depressions or bumps it was the pan that hit.
                                Now like you guys say I hit the lip but I am hyper aware of it and drive really carefully and still I have still managed to scrape it several times in the two weeks since I got her back.
