Cluster 'Check' light
  • Victor_PR
    • Jun 2011
    • 296
    Hi;
    After driving for some time, my car's 'Check' light comes on indicating that there is problem with the Brake lamps. When I arrive at my destination, I park the car but leave it on. I depress the brake pedal with an umbrella so I can get to the back of the car to see which lamp is not working. To my surprise, all brake lamps and driving lights are ok. Any ideas what could be happening? I just hate having the annoying light on the upper check panel.
    Thanks.
    Victor
    Victor
    Rides...
    E30 325i - 1990
    F30 328i - 2014 (DD)
    F25 X3 - 2016 (Family car)
    1974 - 2002 (The ruler of the stable) SOLD
  • Thrizzle
    • Aug 2011
    • 194
    Brake light switch on your brake pedal could be bad.
    • AndrewBird
      The Mad Scientist
      • 11898
      Likely dirty bulbs/sockets. Clean them up with a little sand paper. The check system is finicky about stuff like that.
      • McGyver
        • 4636
        like nitro said, clean up the contacts. mine comes on every time i start my car and goes away the first time i use the brakes. weird and annoying? yes. biggest problem i have? no way.
        • jeffnhiscars
          • Jun 2011
          • 6011
          Damn ! I thought that was normal. Now I have something else to eventually track down... lol
          Alice the Time Capsule
          • themoonman
            • Aug 2011
            • 196
            i always thought it was supposed to do that to get people in a habit of starting their car with the foot on the brake in case of being left in gear.
            • kts
              • Jun 2010
              • 753
              every E30 does this. :)
              the circuit isn't complete and can't be tested until you put your foot on the brakes.
              • dothadance
                • Jun 2011
                • 1121
                truth
                • frankie591
                  • Feb 2012
                  • 545
                  That light also indicates if reverse lights aren't functioning. Get a friend to tell you if they come on when you put it in reverse.
                  • jeffnhiscars
                    • Jun 2011
                    • 6011
                    Auto trans the starter cant energize in gear and in a 5spd if its in gear & you step on the brake, how is the engine going to turn over ?
                    Try the clutch ;)
                      • 34844
                      it's supposed to do that. :-?
                      don't you guys read your factory manuals?
                      • e30vert
                        • Jan 2005
                        • 1789
                        I have a similar question an can start a new thread if needed.
                        Here it is anyway.
                        88 vert
                        Rear third brake light that is normally on the trunk has been removed and a coupe hood fitted. Pretty standard mod there.
                        Here is the difference and the kicker. I added a rear LED third brake light from an e46 and wired it into the same wiring used to supply the standard third brake light.
                        LED third brakelight works titties! However since the LED from the e46 has a different internal resistance than the OEM third brake light which uses an incandescent bulb it causes the Brake Lights LED to be lit up in the check panel.
                        Does anyone know if I can just wire in a 1/2 watt resistor of a certain value (dont know the value?) to the hot side wire that supplies the LED third brake light and have that check Brake Lights LED be turned off?
                        • dnguyen1963
                          • Nov 2011
                          • 2651
                          Here it is anyway.
                          88 vert
                          you'll need at least a 330 ohm resistor to have your LED work correctly.
                          • DaveSmed
                            • Apr 2007
                            • 1407
                            Here it is anyway.
                            88 vert
                            Just connect the two Green/Black wires together.
                            -Dave
                            2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
                            Need some help figuring out the ETM?
                            • e30vert
                              • Jan 2005
                              • 1789
                              PM sent
