Tps continuity test?
  • schtozo
    • 1455
    I found this article but it confused me at the end. Can someone clarify to me whats the correct steps to check for continuity and see if my tps is working properly on wot?
    Article i found
    **** Here’s how you test the switch. First make sure that the battery disconnected. This is crucial. If you fail to do this, you could send a spike through the system and fry the ECU. Now open the hood, and look under the throttle body. You will see a small black box with a plug going into the side. Press and hold down the metal clip on the outside of the switch and pull it off. You will now see three terminals on the inside of the switch. These are the terminals that go to the idle control valve. What you need to do is get a hold of a multi-meter, set it to check for continuity. It will be a tight squeeze getting the terminals under the intake air boot, but it is possible. Now, check for continuity between the left outside terminal and the center terminal. While holding the test probes in place, slowly open the throttle. Just after opening, there should be no continuity. Now test the outside right terminal and the center terminal, and slowly open the throttle to the full position. As you come close to full throttle, you should see continuity return. I you fail to see any continuity return, try loosening the two screws under the switch and rotate it until you have continuity when the throttle is fully closed. If you still fail to see continuity, the switch is bad and must replaced. This was the case in my car.
    One of the best threads you will ever read
    http://www.r3vlimited.com/board/showthread.php?t=221813
    Nice trailer of my e30
    http://www.youtube.com/watch?v=TTjtG...e_gdata_player
    If i sold you something please leave feedback here
    http://www.r3vlimited.com/board/showthread.php?t=217142
  • Jean
    • 18228
    Bentley shows how to do this.
    Auto TPS is more than 3 pins on some cars, FYI.
    • ForcedFirebird
      • Feb 2007
      • 8300
      Late autos with the sport mode.
      TPS is simple. Between the center and idle pin should be dead short until slightly open, then infinite open. Then move the test leads to the center and WOT pin, they should be open until almost full throttle where it will become a dead short on those two pins.
      john@m20guru.com
      Links:
      • schtozo
        • 1455
        Yeah mine is 3 pins tps.
        So dead short is the beep on the multimeter?
        And which pin is idle and which is wot? Left is idle and right is wot?
        Sorry guys i dont have a bently.
        • LJ851
          • 7919
          Install the multimeter on the center pin and another pin. If its a dead short, crack the throttle and see if it becomes infinity.
          If its open (infinity) open the throttle to full and see if it shorts.
          Do the same to the center pin and the other pin.
          One pin should act one way and the other pin should act the other way.
          Lorin
          The M30 is God's engine.
          • schtozo
            • 1455
            Ok, i just checked the tps.
            The center and left pins have continuity with the
            Throttle fully closed, when slightly opened till i hear the click it loose continuity all the way till wide open throttle.
            The center and right pins showed no continuity never.
            So this means that the sensor is faulty right?
            • LJ851
              • 7919
              Sounds like a bad sensor, you have no WOT switching going on.
              Lorin
              • Ferdinand
                • 205
                Or it's mis-adjusted.
                Loosening the mounting bolts allows you to turn the sensor side-to-side. You want it positioned so that the idle switch closes just as the throttle plate is almost closed, and the wide-open-throttle (WOT) switch closes when the throttle plate is wide open.
                The throttle position sensor is just a couple of switches. It does nothing useful elsewhere, only at idle or at WOT.
                The sensor, mounted at the bottom of the throttle plate shaft, tends to fill up with oily gunk that drips down the throttle shaft. Rather than spending money on a new one, it is possible to (carefully) pry it open, clean out all the oily crap, make sure the switches still work, then glue it back together.
                • schtozo
                  • 1455
                  Thanks but i already have a new sensor laying around.. I will remove throttle to install the new one carefuly..
                  • LJ851
                    • 7919
                    Throttle fully closed, when slightly opened till i hear the click it loose continuity...
                    OP is describing a properly adjusted switch.
                    WOT switch happens a fair bit before actual WOT so if the idle switch opens anywhere near closed throttle WOT switch is going to activate (if the switch is good)
                    Lorin
                    • Ferdinand
                      • 205
                      Good point.
                      • bostonvert
                        • Oct 2015
                        • 233
                        Just bought a 1985 520i with the m20b20, the car has a hard time idling especially when cold and slow trottle response.
                        We checked the TPS with the battery disconnected and only at full trottle did we get a readout. The TPS was also moist inside and covered with oil and gunk.
                        I am pretty sure this is the source of my problems, the PO said it was a vacuum leak but no visible cracks.
                        I do have another TPS but from a 1982 m20b20, would this work? Might be worth a shot since a new one is around 130 euro from BMW
                        Instagram : makeitsnap
                        1985 e28 520i
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          Your car "thinks" your foot is always on the accelerator, so it will start and run poorly at or near idle. As long as you don't have the weird automatic TPS (IIRC that's only very late models), then they all "should" be the same.
                          john@m20guru.com
                          Links:
                            • 34845
                            I don't think any US cars came with the "sport selector" (the only cars that got the 6 pin TPS).
                            My auto was a pretty late production and it had a 3 pin TPS. I think it was pretty much on only euro market cars. It also came on M30s.
                            • ForcedFirebird
                              • Feb 2007
                              • 8300
                              Assuming his location, Belgium, is a city in the States ;)
                              EDIT: AND the car is a 520i, not even an e30 - both missed that...
                              john@m20guru.com
                              Links:
