Subwoofers vs Alternators
  • NeoMishMoo
    • Jul 2009
    • 448
    A couple months back I'm driving at dawn and my car starts running terribly, like fuel pump dying, pump the gas little response, I turn off my headlights and like magic it brings my car to life and I'm able to get home. I take my alternator to a machine/drag shop for testing and the guy comes back and says he replaced something on it and charged me $30. Car ran fine for months. Just did it on me again. First indicator is car stereo shuts off. then lights get dim, then car runs awful.
    Haven't gotten my alternator looked at yet but I was just wondering if a high powered stereo could put too much strain on an old alternator. Currently running lukebox with 12" subwoofer powered by 300(rms)watt amp with no capacitor. Nothing crazy but it is enough to dim my headlights at high volumes.
    West German BMWs, they just don't make the same as they did before the wall fell.
    ^Case in point: Auto-Repair Technology. Everytime my car isn't starting or acting up I let it sit, sometimes for an hour, sometimes for days. But it eventually fixes itself.
  • reelizmpro
    • 9558
    Sounds like a voltage regulator. Check it out and make sure the brushes are within spec. Also check the wiring on the alternator itself.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • Kevinl
      • Oct 2012
      • 897
      300 watts in not high power I doubt that's causing your issue
      1989 BMW 325is Lachsilber metallic 5 speed
      2007 BMW 335i KARMESINROT 6 Speed manual
      2011 BMW X5 35I
      • R3Z3N
        • Jan 2011
        • 3056
        I agree with both of the above.
        • TobyB
          • 5296
          i agree with all THREE of the above...
          heh
          t
          • ELVA164
            • 4861
            Check for vacuum leaks.
            • NeoMishMoo
              • Jul 2009
              • 448
              Enough to dim my lights during the sick bass drops, lol.
              300rms is like 8,000 max watts by today's shitty amp standards.
              (my buddy did literally have a 1,200* watt amp that put out only 300rms.
              • Kevinl
                • Oct 2012
                • 897
                A good amp doesn't have a max rating I have Rockford fosgate power 1000bdcp in my suburban and it is actually underrated its more like 1300 rms @ 1 ohm
                I haven't put a stereo in the e30 yet because I cant find a ski pass rear seat:hitler:
                2011 BMW X5 35I
                • R3Z3N
                  • Jan 2011
                  • 3056
                  If it's dimming your lights during those "sick bass drops" then you do have a problem, as you are already well aware of. I have a 600w Mmats D600.1 amp with a Mmats P3.0 10" rated for 1000w, along with a Audison SR5 400w 5 channel amp running my woofers/tweeters with no problems (because it WAS running my sub as well). My lights or other electrical items have no dimming happening when playing something loud with lots of bass IE Utah Jazz: Vintage I don't even consider my setup to be "high powered."
                  • IRON-E
                    • 16548
                    Got 2x12"s, 1200 wtt amp @900rms, droping old school bass all the time.
                    Autozone slternator, bmw regulator and yellow top optima battery.
                    No dimming issues at all, maybe a short with your wiring?
                    @IRON-E30 aka Edwin:D
                    • Cephas
                      • Apr 2012
                      • 878
                      I don't do the system thing anymore, but in my old e30 with a crappy battery and the stock, orginal alternator I ran 2 Alpine V12's, 2x12 MTX subs, components front and 5 1/4's in rear and never had dimming issues.
                      • Gregs///M
                        • Mar 2012
                        • 2459
                        Engine ground cable needs replacing or cleaning. This cable is the ground loop for the starter and alternator, which supply both power and ground for the battery and the rest of the car electronics.
                        A poor engine ground cable will cause the exact symptoms you just listed, especially with moments of high current demand (bass notes)
                        Start there. Consider my cables which can be found in my signature, they are heavy duty, and almost twice as thick as OEM. Perfect for cars with Sub systems.
                        Owner - Bavarian Restoration
                        BMW and European Electronics Repair and Restoration
                        www.BavRest.com
                        My Feedback Thread
                        Our Facebook!
                        Follow our Instagram!
                        • NeoMishMoo
                          • Jul 2009
                          • 448
                          I am going through cleaning my ground connections, if problem persists I will consider your cables.
                          I guess I should have stated "powered" and not "high powered"
                          I realize that I have a problem, my main question was to whether or not these conditions could permanently damage the alternator. Seeing as how I have had to have it serviced once before.
