odometer intermittent
  • downforce22
    • Aug 2009
    • 3193
    I already replaced the gears and double checked they are in place.
    I heard the diff sensor could have a bad connection so I looked at it and it looks shiny and silver on both connectors.
    What else could cause my odometer to work intermittently? Everything else on the dash works fine.
  • ELVA164
    • 4861
    How long ago did you change the gears? Just after I changed mine, there were a couple occasions where the odometer stopped working then started up again on its own.
    • downforce22
      • Aug 2009
      • 3193
      The gears worked fine for 2000 miles and then started to become intermittent. It has been another 1000 since then, going for a few hundred, then a few 10 or so and now even less.
      • ELVA164
        • 4861
        It may be worth your time to pull the gauge out and make sure the gears are functioning properly and aligned. No previous experience here, but it sure sounds like something is mechanically failing...
        • BlackbirdM3
          • 2773
          It might also be that the cover for the little motor that makes everything work has tightened up. I replaced my gears and they didn't work, pulled the cluster back out, took it apart, futzed with things, loosened the clear cover and it worked fine after.
          Will
          '88 BMW M3
          • downforce22
            • Aug 2009
            • 3193
            I pulled it out and it was working just fine, put it back in, worked for a quarter tanks and still intermittent. Could the si board batteries be going back?
              • 34847
              Si board has no control over gas gauge, odo or speedo.
              • Poorboyz
                • May 2012
                • 2117
                I've been having the same problem ever since I got my car back in early summer of 2012. Problem will be getting fixed soon by Gregs///M
                Rebuilding since 07/06/2016
                Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
                Poorboyz Feedback Thread
                • downforce22
                  • Aug 2009
                  • 3193
                  How is he going to fix it?
                  • Gregs///M
                    • Mar 2012
                    • 2459
                    I can install gears, repair, and adjust the odometer. I have a test bench setup where I can test the odometer assembly and cluster as a whole. This will help me guarantee that the odometer I am working on is put together correctly and working according to spec.
                    The gears themselves can be tricky to get right the first time. VDO gears can easily be incorrectly installed yet seem like they mesh correctly. Also the plastic door can attribute to intermittent odometer operation.
                    Owner - Bavarian Restoration
                    BMW and European Electronics Repair and Restoration
                    www.BavRest.com
                    My Feedback Thread
                    Our Facebook!
                    Follow our Instagram!
                    • downforce22
                      • Aug 2009
                      • 3193
                      Thanks Gregs... They have been working fine for the last 30 miles. I am wondering if it has to do with temperature.
                      How do I know if the plastic cover is too tight?
                      • Gregs///M
                        • Mar 2012
                        • 2459
                        You can't really tell unless you run the odometer. I barely torque those screws enough so there is no play of the plastic cover.
                        www.BavRest.com
                        My Feedback Thread
                        Our Facebook!
                        • GOT8SPD
                          • 270
                          I have this issue with my odometer as well. I really want it fixed :(
                          I changed the gears using gears from Garagistic. It worked fine and I had no issues then it just stopped working. I have the spacers installed and everything. What do i do now? Where is this diff sensor?
                          • brahbarian
                            • Mar 2012
                            • 153
                            Mine does the same thing. But it's also the speedometer and the odometer. Everything else works. Just intermittent. If I drive for a long while it'll kick on.
                              • 34847
                              The wires at the diff sensor are probably broken
