Help With Aux Fan (Been Searching All Day)
  • dr.gonzo
    • Nov 2009
    • 206
    I bought a new resistor, but the fan wouldn't jump when I connected the low speed (at the temp sender unit) so I took the resistor out and bridged the wires. It worked before with the resistor when I had the ac on but nothing now (new spal fan) any insight?
    www.roadreview.net
  • dr.gonzo
    • Nov 2009
    • 206
    So I noticed fuse 3 was blown. I replaced it and the new fuse blew immediately after the fan spun. Is that because I didn't have the resistor in?
    Sent from my SGH-M919 using Tapatalk
    www.roadreview.net
    • downforce22
      • Aug 2009
      • 3191
      I would venture to say yes
      • AndrewBird
        The Mad Scientist
        • 11896
        The fan is going to draw the same amount of current with or without the resistor.
        Did the fuse blow immediately as you were putting it in, or when you turned the fan on for the first time?
        The Spal fan might draw more than the stock fan, which would cause it to blow fuses.
        • dr.gonzo
          • Nov 2009
          • 206
          It's a hi flow spal unit. What I'd like to know is why the low speed is not working
          www.roadreview.net
          • kingston
            • Jun 2010
            • 2669
            There are separate fuses for high & low speed, I believe, and you will need to put in higher amp fuses on both
            Originally posted by LJ851
            kingston is the play by play announcer for this thread.
            ‘Tis by the grace of God that my cars run!
            Originally posted by unloadedak
            #teamross
            Siobhan's Build Thread - UPDATED!
            • dr.gonzo
              • Nov 2009
              • 206
              Yes the fuse blew immediately
              Sent from my Nexus 7 using Tapatalk
              www.roadreview.net
              • AndrewBird
                The Mad Scientist
                • 11896
                DO NOT just put high amperage fuses in. The fuse are there to protect the WIRING from overloading, so if you put a higher amperage fuse, the wiring will then burn/melt instead of the fuse.
                It sounds to me like there is a short somewhere. Could be a bad relay perhaps.
                • dr.gonzo
                  • Nov 2009
                  • 206
                  Pretty sure I've replaced the relays. Any easy way to check?
                  www.roadreview.net
                  • FLG
                    • Sep 2011
                    • 3165
                    If you jumped the resistor you will need to put the same amp fuse thats on the high side into the low side as well. I run my fan like this and have never had issues even on super hot track days.
                    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                    • jeffnhiscars
                      • Jun 2011
                      • 6010
                      Kingston is correct on this. Both the high and low circuits use a .75wire so each is capable of carrying the full demand of the fan. You just need to up the low speed fuse to handle.
                      Alice the Time Capsule
