Heater not hot enough
  • Th3importedguy
    • Mar 2014
    • 190
    My heater is all that hot. In the morning it's just not hot enough. I'm not asking for fire but just warmer.
    E30 is life :finger:
  • KIRIEIW
    • Dec 2012
    • 3385
    I'm also in for an answer. What does your temp gauge show when the cars fully warmed?
    1992 e34 Touring- S50 Swap
    1992 325i-S50 Swap (SOLD)
    1991
    • Cabriolet
      • 9620
      how far are you driving? it takes about 10 minutes for most e30s to get to full warm on the heater.
      but you may need to bleed the car again as there most likely air bubbles stuck in the core.
      Much wow
      I hate 4 doors
      • dsphil
        • 495
        Did you turn on the recirculating air? It helps because you're not trying to heat up 32deg outside air like today.
        327is
        325es
        325es
        318is
        Fiesta ST
        E46 M3
        • efficient
          • Feb 2012
          • 3312
          i got a new heater core and now it blows real hot compared to my old one.
          • CorvallisBMW
            Long Schlong Longhammer
            • 13039
            OP, there's a lot of things that it could be:
            -clogged heater core
            -malfunctioning heater valve
            -malfunctioning air flap thingys
            -engine not reaching operating temp (stuck open thermostat, etc)
            -air trapped in coolant system
            I'd check engine temp first, then bleed out any air. Good luck!
            • Stanley Rockafella
              • Aug 2011
              • 4060
              before I replaced my rad, my heater was hotter than hell
              • Graebmw95
                • Mar 2014
                • 362
                +1 What he said.
                Check for all of those..
                Also, when you replaced your radiator did you do a complete coolant flush? Did you make sure there is absolutely no air in the system?
                I know I had a problem where my heat wasn't very hot either and I was low on coolant.. So I'd make sure that you A: have no air in the system, ad B: Are full on coolant. Heated coolant is what goes through your heater core and if you're low than that could be your issue.
                • dnguyen1963
                  • Nov 2011
                  • 2649
                  In the snowy region, it can take up to 20 min for the car to get up to normal temp (needle in the middle). When it is 20F the needle barely goes pass the 1/4 mark in the first 20 min of driving in my car.
                    • 34839
                    mine always heated up quickly (~5 minutes) even on freezing cold days. there's actually a pictogram on the heater controls that shows you what positions to move everything to when defrosting the windows, maybe this also helps it heat up faster.
                    • blunttech
                      • 12850
                      90% of these issues is air in the system. Get the front end up as high as you can... Either on ramps or a really steep hill. Get the car up to temp with heater valve open and nail the throttle a couple times. Then open the bleeder and repeat until you get only coolant.
                      sales@blunttech.com
                      www.blunttech.com
                      Like us on Facebook
                      • dnguyen1963
                        • Nov 2011
                        • 2649
                        You guys do not know what winter is like...
                        http://www.seattle.gov/living-in-sea...es-and-records
                          • 34839
                          I don't live in seattle
                          • jeffnhiscars
                            • Jun 2011
                            • 6011
                            I've lost track of how many times I've drained coolant for one reason or another among my hoard of e30s and have never ever had a bleed issue. Since I know it's a real issue the only thing I can think of is that I make sure there is a 1/16 bleed hole at the top of the tstat.
                            Then again I've also never had a problem getting a fan clutch off with just channel loks so maybe I'm just lucky :)
                            Alice the Time Capsule
                            • uturn
                              • Dec 2010
                              • 1004
                              I used to live in Seattle... but the problem with no heat in my e30's were faulty heater control solenoids.
