fuel filler neck
  • long tall eta
    • Jul 2010
    • 1536
    fuel filler neck
    while getting gas the attendant told me he thinks i have a leak in my filler neck. i was in the store at the time so maybe he just spilt some. if the neck is ruptured, what is the replacement process? will i have to drop the tank? can't find this fix in the bently.
  • Todd Black 88
    • Oct 2007
    • 3449
    It's a separate piece from the tank, and there is a hose attaching it to the bottom of the the tank. Mine hose cracked and leaked. Check there.
    Originally posted by codyep3
    I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
    2001 silver/Blk 325 cabby. SOLD
    2002 325xit Sil/blk. SOLD
    2010 F650gs twin
    • long tall eta
      • Jul 2010
      • 1536
      but if it is cracked, will i have to drop the tank? can't check it now, it's close to 0 outside.
      • Quadrajet
        • Jul 2008
        • 1278
        Shouldn't have to drop the tank. Kind of annoying place to work though.
        • Mr. Tasty
          • Jul 2011
          • 3421
          no
          2014 Alpine White 335i MSport
          (Daily Driver)
          Full Mperformance Aero
          KW V2 Coilovers
          VRSF Catless Downpipes
          • rturbo 930
            • Dec 2005
            • 2629
            Why exactly does he think you have a leaky filler neck? Was fuel spilling onto the ground? Because that could be caused by a couple things.
            • long tall eta
              • Jul 2010
              • 1536
              yes, there was a small amount of fuel spilled on the ground. tank is presently full and not leaking so i'm sure it's not the tank itself. what else could it be. loose clamp?
              • rturbo 930
                • Dec 2005
                • 2629
                Well, when I first got my car, on the trip home I had to fill up, and once it was full, fuel just started spilling onto the ground. I think it was an O ring or gasket on top of the tank for once of those access lids. I don't remember exactly.
                • Das Delfin
                  • Sep 2014
                  • 2293
                  ...it's entirely possible the guy could be a moron.
                  • jeffnhiscars
                    • Jun 2011
                    • 6011
                    this ^
                    If the back pressure setting on the pump is not set correctly if can overfill your tank which will spill fuel through the rubber collar at the filler opening.
                    The filler neck itself is steel but if you truly have a leak and its not the tank, its likely to be the hose that connects the neck to the tank. I changed mine when I had my subframe out cause it was easy (and cheap). Im not sure about changing it with the SF in place but I suspect its somewhere between a root canal and cutting your arm off
                    Alice the Time Capsule
                    • TobyB
                      • 5297
                      It's also quite possible that the metal y- pipe up there has rusted out.
                      They don't seem to be rust- proofed, and Jersey seems to rust everything.
                      You have to pull the right rear wheel and the cover that's over the return and vapor
                      pipes, but then you can see almost everything.
                      t
