Heater is only pushing kinda warm air
  • FireFight
    • Mar 2012
    • 1367
    Hey guys, my ladies e30 doesn't push heat. Thinking it was a stuck heater valve I replaced that($$$) and no improvement. I'm fully bleed as far as I can tell.
    The car use to blast heat last winter but it did have an m10 at the time, now m20 powered, is it true that hoses could get mixed around? Cause if I touch the heater core it is hot
    WTB:m60b40 in PNW
    Zachary Ripley
    85 318i M50B25tu.
    92 525it 5 speed.
    80 244gl (m60 prepping).
  • Bearmw
    • 1323
    Are you saying that the heater core temp is the same at both the inlet and outlet or is it just at the inlet? Is it hot at the inlet?
    • Das Delfin
      • Sep 2014
      • 2293
      Yeah it does matter which hose goes where. Find a diagram and check to see if it looks right
      I have to turn my temp dial all the way hot to get heat. If you haven't done that, try it.
      • efficient
        • Feb 2012
        • 3312
        Are you sure you bled it properly?
        You should prime the heater core with coolant, and the hose from the back of the head goes to the top heater core line. Then rebleed the system.
        • FireFight
          • Mar 2012
          • 1367
          Yep, both the upper and the lower pipes are to hot to touch, and the part of the heater that is exposed with the center console out it hot.
          WTB:m60b40 in PNW
          Zachary Ripley
          85 318i M50B25tu.
          92 525it 5 speed.
          • FireFight
            • Mar 2012
            • 1367
            ill double check those hoses then, i usually keep the dial all the way to heat so it should be open
            WTB:m60b40 in PNW
            Zachary Ripley
            85 318i M50B25tu.
            92 525it 5 speed.
            • FireFight
              • Mar 2012
              • 1367
              Ill try popping off the hoses and pouring coolant directly in to the lower and let air escape though the top, but the car doesnt show any signs of not being bled (doesnt over heat, heater is hot to the touch
              WTB:m60b40 in PNW
              Zachary Ripley
              85 318i M50B25tu.
              92 525it 5 speed.
              • mr.vang
                • 4371
                Where is the temp needle in the temp gauge? If it is in the low side, your thermostats might have stuck open.
                • FireFight
                  • Mar 2012
                  • 1367
                  it does have a hell of a time getting to operating temp, usally hangs around 1/4 if driving
                  WTB:m60b40 in PNW
                  Zachary Ripley
                  85 318i M50B25tu.
                  92 525it 5 speed.
                  • jeffnhiscars
                    • Jun 2011
                    • 6010
                    Are you sure your blend door is moving when you turn the temp dial ?
                    Alice the Time Capsule
                    • Kershaw
                      • 11822
                      Maybe your thermostat is broken.
                      AWD > RWD
                      • Das Delfin
                        • Sep 2014
                        • 2293
                        ^ +1 check your t-stat. It should get above the blue in 5 mins or less. It may even be something stupid like the t-stat gasket is installed on the wrong side of the t-stat
                        • McGyver
                          • 4553
                          I would guess that you have air in the system because your heater core hoses are on backwards. It 100% DOES matter which way you put the hoses on since the inlet/outlet ports for the heater core are stacked vertically in the engine bay. So you need the hot coolant to go into the bottom port so it can push the air out the top as the coolant circulates. If you go the other way around you are trying to push air down through your heater core and fighting the air trying to rise. This will let a trickle of coolant go through (enough to warm the hoses), but not enough to actually heat. It may also give you overheating problems.
                          Here's a realoem diagram with coolant flow depicted. The Inlet (17) goes into the bottom, the Return (18) comes out the top.
                          • FireFight
                            • Mar 2012
                            • 1367
                            My top hose that goes to the heater valve goes to the thermostat housing and the lower to the block. So those should be right.
                            I swapped out my thermostat for a factory one and I have a little more heat but it still won't go to OPT temp. The fan seems to be free spinning so I don't think its a froze fan clutch. It has no shroud or AC condencer so idk if those would have any play
                            WTB:m60b40 in PNW
                            Zachary Ripley
                            85 318i M50B25tu.
                            92 525it 5 speed.
                            • FireFight
                              • Mar 2012
                              • 1367
                              Now the car is totally cold I found I can't stop the fan so I think the fan clutch isn't letting loose
                              WTB:m60b40 in PNW
                              Zachary Ripley
                              85 318i M50B25tu.
                              92 525it 5 speed.
