Fuel line sizes?
  • e30onBBSs
    • Dec 2014
    • 1347
    Fuel line sizes?
    Hey r3v I am compiling parts for a head swap and stumbled on this hose on realOEM. Is there a cheaper alternative? Is there a standard hose size for the car?
    13311722565
    https://www.fcpeuro.com/products?keywords=13311722565
    http://www.realoem.com/bmw/enUS/show...diagId=13_0267
    Number 12, simple short hose $30? Anyone found away around this price? I'm willing to pay the money if it's necessary but it seems like it's no different than a normal fuel hose besides the 90 degree curve. Thanks!
    BMW tech
    Umass Amherst
    05 wrx sti
  • TimeMachinE30
    • Jun 2014
    • 3749
    Remove hose. Take it to local hose supply. I have a few industrial hose supply houses around that sell by the foot all sorts of hosing a d provide crimping/terminating services, too.
    The hose I replaced the oil cooler lines on my W126 are a serious upgrade. I think you could re-hose a vehicle for less than OEM money all the while with better material.
    Can always go to AutoZone, too.
    ACS S3 Build / Dinan 5 E34
    • digger
      • Nov 2005
      • 6143
      It's usually 5/16" or 8mm hose
      The moulded hoses are expensive,the non moulded hoses they just call up the hose with appropriate ID then you just buy a whole length and cut to size
      Some moulded stuff has they radii so you can't readily use normal hose
      • jeffnhiscars
        • Jun 2011
        • 6011
        Fuel line is 8x13mm and must be rated for fuel injection or it will break down from the ethanol in gas. Like time I bought 5m which is enough to do 2 cars under the hood and I paid about $32 for the roll.
        5/16" is an ok substitute for you imperialists out there :)
        The only molded fuel hose I ever buy is fuel pump to fuel filter for about $6 but even that I've gotten away with bulk hose.
        Oh...the last time I bought fuel line at the dealer...they gave me 5/16. So much for purity !!
        Alice the Time Capsule
        • Das Delfin
          • Sep 2014
          • 2293
          I got mine from bavauto b/c I heard horror stories of parts stores fuel line not beign able to withstand the fuel pressure of bmw fuel systems.
          I used 16121180409 for the front of the car.. haven't done the back yet. It's sold by the meter. I got four meters and used more than half in the front
          • jeffnhiscars
            • Jun 2011
            • 6011
            That would be from buying Jose that is not FI rated
            • digger
              • Nov 2005
              • 6143
              Fuel injected hose isn't necessarily ethanol resistant. It's a different pressure rating to regular fuel hose. I use ethanol rated fi hose when I replace hoses nowadays just incase I ever want to use it it's one less thing to worry about
              • TimeMachinE30
                • Jun 2014
                • 3749
                That is a great idea. Ethanol seems like a nasty additive. Just from JEGS or where do you get yours?
                • jeffnhiscars
                  • Jun 2011
                  • 6011
                  It may just be that no one sells FI hose here that is not ethanol resistant. since its very difficult to avoid ethanol it's become the norm.
                  May be different down under
                  • e30onBBSs
                    • Dec 2014
                    • 1347
                    so is the final conclusion that if I bring the hose to a parts store or a store that sells hoses it will suffice?
                    BMW tech
                    Umass Amherst
                    05 wrx sti
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      As long as it's "fuel injection hose" and not just "fuel hose".
                      john@m20guru.com
                      Links:
                      • e30onBBSs
                        • Dec 2014
                        • 1347
                        Sweet thanks everyone! I knew I wasn't tripping when I thought $30 was expensive lol
                        BMW tech
                        Umass Amherst
                        05 wrx sti
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          I buy it by the meter from BMW, and it's not overly expensive compared to the parts store. Expect $4.95/ft (or more) for a parts store at average price.
                          john@m20guru.com
                          Links:
                          • TobyB
                            • 5263
                            Poor Jose...
                            hee.
                            High pressure fuel hose is pretty easy to come by, these days...
                            t
                            • modernist
                              • Apr 2014
                              • 283
                              I use HBD Thermoid FI-503. Expensive but excellent quality. Nicer than OEM in my opinion.
                              1986 327i
                              transaction feedback
                              DIY thing
                              meh
