Oil light on
  • dmb62
    • Oct 2015
    • 42
    Oil light on
    Hey once again. I just got my oil change done 2 days ago but unfortunately my car slid Into a ditch last night. Luckily I slid just off the road and my car didn't even scrape the ground and I have no dame done but just needed to be pulled out. One concern is though that my oil light is on in my dash not the same of the overhead display engine oil light. I'm just wondering what common things are that can cause this as my oil has just been changed and I checked the dipstick and it's full. Thanks car : 87 325e
  • dmb62
    • Oct 2015
    • 42
    Cars starting to overheat
    • digger
      • Nov 2005
      • 6196
      That's oil pressure light. Not the oil level. Hopefully it's a faulty sensor otherwise the engine is probably quite sick. Is it on always ?
      • modernist
        • Apr 2014
        • 283
        Oil pressure light should never be on when the engine is running. If it is, something is seriously wrong.
        Alternately, the wire to the oil pressure switch is grounding out somewhere and triggering the light. If the light doesn't go away after unplugging the switch, you have a short.
        1986 327i
        transaction feedback
        DIY thing
        meh
        • dmb62
          • Oct 2015
          • 42
          It just appeared today for the first time. I have receipts from engine rebuild done from previous owner 60xxxkm ago
          • Dirty325ix
            • Sep 2012
            • 689
            I want to see pictures of this supposed ditch
            Run the car with the oil cap off for second and peak in, you should see some oil splashing around in the head. If you do then it's just a wiring issue and if it looks dry than maybe the oil pump is fecked. Hopefully it's just a problem with the wiring.
            • Kershaw
              • 11822
              Did you slide into the ditch on the passenger side? That's where the pressure sender is. I bet you tore your wiring.
              AWD > RWD
              • 101
                • Jul 2011
                • 764
                ^^^ that. That single wire going to the oil pressure switch is quite vulnerable.
                101
                The E30 collection:
                1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
                1987 325is - Delphin / Black Sport (son #3's)
                1987 325i Convertible - Triple Black
                1989 325iX Coupe - Diamondschwarz / Black Comfort
                1990 325iX Coupe - Sterling Silver / Grey Sport
                1981 Fiat 124 Spider 2000 - Green / Tan
                1998 Volvo V70 GLT - White / Tan
                1998 Volvo S70 T5 manual - White / Taupe
                2001 Ford Windstar - Silver / Grey (parts hauler)
                2006 Lexus GX470 - White / Tan (tow rig)
                • dmb62
                  • Oct 2015
                  • 42
                  Indeed it was the passenger side. Il look into oil pressure switch thanks :)
                  • JeLani
                    • Aug 2015
                    • 1552
                    My oil pressure light has been on too, only at high(er) revs. This happened alot when it would start to overheat when i was trying to bleed the thermostat. What could that be? My hg is gone too.
                    1986 LTW M52 (First project 2015- )
                    1998 e36 328ic/5 -
                    Roundie alpina pig cheek’d (1969)
                    1967 2002 parts car
                    1994 318iS junked.
                    • 101
                      • Jul 2011
                      • 764
                      JeLani:
                      What viscosity oil are you running and what temperatures are you driving in?
                      Three things that I think may be causing your issue:
                      - You may be running real thin oil in a really hot place or without sufficient cooling. It's been debated at length here, but 15W40 should be a minimum in San Diego. You can probably safely run 20W50 out there. Double check your owner's manual on that point.
                      - Your oil pressure sending unit may be shot.
                      - Your bearings are worn and the enlarged clearances drain the oil pressure.
                      The above list gets more expensive, reading from top to bottom. Unless your engine has high miles or was not maintained well, the last possibility is also the least likely.
                      101
                      The E30 collection:
                      • jeffnhiscars
                        • Jun 2011
                        • 6011
                        I'm surprised no one has raised the possibility that he punched a hole in his pan and the oil is now in that ditch...but then if the engine has run more than say 2 minutes since the light came on forget what I said.
                        Alice the Time Capsule
                        • dmb62
                          • Oct 2015
                          • 42
                          I checked oil level and its full and I haven't noticed any leaks in driveway. I haven't taken a good look at oil pan but I believe it's fine :)
                          • e30onBBSs
                            • Dec 2014
                            • 1347
                            aaand it's time for an oil pressure gauge!
                            BMW tech
                            Umass Amherst
                            05 wrx sti
                            • UlrichFennec
                              • Dec 2014
                              • 1268
                              Mmmm...compression tests.
                              "Leafeon" '92 Lagunengrun 325i Vert (Daily Driver/Project)
                              http://www.r3vlimited.com/board/showthread.php?t=366044
                              The stickers make it go faster. :nice:
