whats the naturally aspirated limits power wise of the m20
  • natorious
    • 672
    what kind of power levels have been reached with the m20 (and have it still be able to be consided an m20)
  • E30godz
    • 1524
    what are the natural limits of your wallet?
    • Jordan
      • 12913
      I would say about 250 hp at the crank.
      https://mtechniqueabs.com/
      • 318driver
        • 1714
        what would have to be done to get #s like that?
        90 325is
        IE stage 3s and refeshed m20....
        • Jordan
          • 12913
          Full 3.0L buildup
          Aggressively ported head
          Larger valves
          Lightened and blueprinted internals
          High C/R
          Dbilas multi TB intake
          Aftermarket engine management
          Upgraded fuel system
          Extensive exhaust work
          When all is said in done, IF you manage 250hp, it likey wont be overly street friendly, and pump gas wont be its friend.
          • SlammedE30
            • 741
            Full 3.0L buildup
            Larger valves
            High C/R
            Exactly, and double word to the pump gas comment.
            -Ted
            • matt
              • 3731
              you forgot a cam with huge lift and overlap.
              Matt
              • Jordan
                • 12913
                Matt
                Yeah, just toss a 302 cam in there with 12mm lift. That should do it.
                • bmwannabe
                  • 900
                  shit i thought you could make more than that NA. Heres an example: 171 base+24(JC chip)+10-20 full exhaust+ 41 Dinan intake manifold + 15 cams valve work ect... Thats 266 conservatively. Now the Dinan manifold may be less, but their claim is 41, correct me if im wrong on all of this.
                  • Jordan
                    • 12913
                    Lets just say this...
                    a m20 build to the limits of street friendlyness has less hp then a s50 with a intake & chip.
                    • Charlie
                      kid tested, administrator approved
                      • 6686
                      I'd say with a 15k budget, ~240-250 crank hp would be tops.
                      3 litre crank, ITB's, MAF, high comp pistons, 288-302 cam, etc.
                      -Charlie
                      Swing wild, brake later, don't apologize.
                      '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                      FYYFF
                      • Charlie
                        • 6686
                        The "Gran Tourismo" method of modding doesn't work in real life.
                        The conforti chip on the 2.5 M20 gets you about 14 hp, a full header system with an exhaust nets you about 5 hp, cams depend on the rest of the motor, and that Dinan head peice has been pretty much shot down by every reputable source.
                        -Charlie
                        FYYFF
                          • 34839
                          you should mention that the JC chip doesn't give you 15hp peak, but 15hp in other areas of the powerband (effecively giving you more area under the curve)
                          • Jordan
                            • 12913
                            Thanks for that, I was sipping a soda, and as I read that.. I spit it all over the keyboad because I was laughing so hard.
                            • Charlie
                              • 6686
                              Don't forget to add in stage 3 weight reduction and a set of super slick tires.
                              -Charlie
                              FYYFF
