Injector’s pintle cap fell into the intake manifold
  • Stapes
    • Feb 2015
    • 117
    While replacing gaskets on my ix, I also decided to serviced the injectors with those kits sold by Injector-rehab.com After runing the engine I noticed one of them leaking, so I decided to upgrade all injectors with Bosch’s Gen2.
    The thing is that when I separated the fuel rail from the air intake manifold, the pintle cap from four injectors separated from the injectors and stayed in the manifold. Eventually they just felt inside the manifold. I wonder if they were of questionable quality.
    Have you run into a similar situation, and how did you removed those caps from the air intake. I don’t mind removing the intake but I’m also looking for a creative solution.
    Here’s the pintle cap I bought: http://injector-rehab.com/shop/BMW-F...arge-Hole.html
    Thanks
    E
  • uturn
    • Dec 2010
    • 1004
    A flex claw tool grabber or a small tygon hose taped to the end of a vacuum.
    • TobyB
      • 5263
      I blow them through the exhaust by using high engine revs...
      t
      lives dangerously
      • ForcedFirebird
        • Feb 2007
        • 8300
        t
        lives dangerously
        I have seen them slightly bend valves :/
        One tine had one fall off and used two shop vacs. One blowing in the exhaust, one sucking through the TB and it came out.
        john@m20guru.com
        Links:
        • Stapes
          • Feb 2015
          • 117
          I ended up using a tygon 1/2” hose taped to my shop vacum. Suction wasn’t that strong but with care and patience it held the pintle cap all the way through the injector hole. Once I set-up the hose, it took me about 40 minutes to get all four caps out.
          I inspected the caps and found that the rib inside is too narrow and the diameter it creates is not enough to make a tight fit with the injector. It was very easy to remove each cap with my fingers.
          Thanks for your replies.
          • KIRIEIW
            • Dec 2012
            • 3385
            I had this happen before, I ended up loosening all the intake manifold fasteners and pulling the manifold back slightly to finally get it out. Same issue as you, the pintle caps weren't a tight enough fit on the injector and it un clipped itself upon removal.
            1992 e34 Touring- S50 Swap
            1992 325i-S50 Swap (SOLD)
            1991
            • Stapes
              • Feb 2015
              • 117
              Who did you buy your caps from?
              • cory58
                • 1021
                Read original post.
                1992 325i Cabrio
                1988 320i Touring
                2000 M5
                1977 530i
                2015 328i - Euro Delivery/Performance Center Delivery
                BMWCCA
                E30CCA
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  As far as the aftermarket pintle caps, I have yet to find a a product that holds like the OEM units. When rebuilding injectors, I actually swap over to the regular hat style for this very reason.
                  john@m20guru.com
                  Links:
                  • KIRIEIW
                    • Dec 2012
                    • 3385
                    I had them rebuilt from a member on here by the name of "MEPEH".
                    1991
