coolant leak, end tack is cracked fml.
Each time you have a new problem on your E30, post here.
just dropped tranny to fix input shaft seal. 1 day after re-install, rear main seal starts leaking oil. Now clutch is slipping over 4k rpm.
Ordered new clutch disk and parts, dropping again next weekend to fix this crap.Comment
So here goes hope I remember everything
When I brought her home *on a truck*
Clutch slave bad *Fixxed*
ABS controller bad *Deleted*
Brake master cylinder bad, 318 master bought ABS deleted *Fixxed*
rubber Brake hoses "swell" All 4 corners new steel braided lines *Fixxed*
Snapped the end off the rear brake (you know the one that connects the rubber house to the caliper? fml) "hardline" on the drivers side cause I'm an idiot" *fixxed*
All 4 shocks BLOWN, JOM coil overs bought *Fixxed *
Center support bearing was screaming like a banshee *New one installed fixed*
Guibo look like it was an exploded baseball *Fixxed*
Driver seat was an old nasty comfort seat *Racing seat installed FIXXED*
Driving home from my buddies shop my shift linkage decides its going to fall off at the light RIGHT before I turn to go into my neighborhood its stuck in 4th FML new shift linkage parts bought *Fixxed*
Now first time on track!
Engine mounts broke Alternator (the fan bit on the front mind you) hit my coolant hose tore a hole in that bitch! newhose *Fixxed*
Second time on track
Forgot my engine mounts where broke this time the power steering pump braket cut a whole in the coolant line. new hose AGAIN *Fixxed*
NOW 2 nights ago
Welded diff *not really a fix but w/e drift spec lawl*
NEW MOTOR MOUNTS *FIXXED*
Let my dad drive her around the block on time he made a U turn to come back.. he's never driven a lowered car before hit the curb with my front lip (thats all he took out thank god) *Zip tie stitch fixxed*
Keep in mind when I put *fixxed* Next to something its with ALOT of help from my lil bro and a few of our friends.
Things "to do"
New LCA's with new bushings
e36 rack swap
New solid m3 LCAB's
New tie rod ends
Been extra lazy since its 110+ here in AZ this time of year.Last edited by Tron; 07-08-2011, 02:48 PM.
Brake pads and rotors
Shifter
BUY MY WHEELS! BBS E50s!!
http://www.r3vlimited.com/board/showthread.php?t=275407
Originally posted by Lurker27Any man will tell you being blown is better than being stroked.Comment
Ah, the trunk. Just ran into this issue as well, although my trunk is just stuck shut (I think the 100 degree heat and humidity had something to do with it) and I can't get it open.Comment
For some odd reason my driver side window won't role up all the way, the motor and switch works fine. There's like an inch gap of open window, wtf?sigpic
1991 318is - Sold
1986 325 - Sold
Instagram - LamoursumComment
Advanded Delphin Division
My e30s: 1987 325i/1994 318iT
Long flat head through the right side of the grill will pop the latch. Use that until you get around to replacing cable.Been with me for 16 years...
Wish i had more time to play with herComment
The new problem...I haven't broken anything or encountered a problem for a few weeks. Weird!Comment
Bad Ball joints. damn. Although i thought they might be 250-300 each and Pelican has them for a bill. That made me happier. Need to start ordering a full suspension revamp. Bushing shocks etc and i will be making my first order to Blunt.Been with me for 16 years...
front tweeters arent working and right front speaker..
runs like shit (no power above 4800)
has some weird suspension problem. (soon to be figured out)
and needs washed.sigpic
^Back in the game^
BUILD THREAD: http://www.r3vlimited.com/board/showthread.php?t=201281
FS thread:
http://www.r3vlimited.com/board/showthread.php?t=214105Comment
