Heater doesn't work when sitting at a stand still
Each time you have a new problem on your E30, post here.
Broke a rocker arm, and a chunk of it got smashed into the head by the cam, leaving a good size hole in the water jacket. FML87 325isComment
Trunk alignment is loose
Creaking noise from the front end of the car
Driver's side window works erratically
Passenger side window makes a clicking noise after it reaches the top
Hood release cable is shot
Wipers stopped working
Heater/AC Fan does not work on any level
Erratic battery drain
Driver's side light dome does not turn on but works when the door is open
Driver's side rear window trim flew off on the highway
There's more I'm sure... :)Comment
my car has no cold idle meaning when i start it first thing in the AM it fires up, revs to about 1200rpms then drops right down to 600rpms or so.
Originally posted by nwvb bmwThat guy is going to lock you in his basement and make you ware a little pirate costume.Comment
sunroof barely closes out of nowhere, fuel guage, exhaust leak, a/c, and valve stems seals need to be replaced.Comment
Came out of class, hit the brakes... pedal goes straight to the floor. Was fine two hours before. Drove it through heavy rain runoff. Could that be related?sigpicComment
haha this is going to be the BUSIEST thread ever...
Current list:
Bad outer tie rods
Bad rh control arm
Shocks are old as balls
Bushings are just as old
Brake light on active check panel wont go out
oil pan is leaking
rear door panel dont match front
1987 BMW 325ic - EmmaComment
