Engine Fan Delete
  • Jand3rson
    • 37587
    #61
    Originally posted by DaveCN
    Josh, they are not that expensive. Think I paid like 18-20 bucks at the dealer with CCA discount.
    I know, I'm not worried about the cost, just wondering if it mattered if it was used or new. I'll just get one new.
    • e304me
      • Feb 2006
      • 1374
      #62
      i ripped out the factory fan and mounted a 3300cfm fan on the radiator, using the factory wiring. I will have to see about getting that fan switch
      • Jean
        • 18228
        #63
        Originally posted by ddavidv
        Did you figure out those brackets yet? They are a little confusing. You have to 'rob' the speed nuts from other locations (condenser?) so the bolts have something to thread into. The bottom mount to me didn't really fit right. I think I had to shim it with some washers or something.
        Nope, I can't figure out how the brackets are supposed to mount to the body of the car...
        • ddavidv
          • 344
          #64
          Jean, email or PM me and I'll see if I can't help you.
          The E36 temp switch is news to me...anyone have a p/n they can get me?
          • Jean
            • 18228
            #65
            ddavidv, got the brackets and all the hardware and they fit correctly but the bottom mounting bushing/bracket seems out of place or off by about an inch from the hole .
            • ddavidv
              • 344
              #66
              Off vertically, or off side to side?
              Mine was off vertically. I think mine ended up just being used to keep the fan from pivoting and never actually wound up bolted to the bottom of the radiator support.
              • Jean
                • 18228
                #67
                Off side to side, basically the top left and right metal brackets lined up fine but not the 3rd mounting bushing with the expanding rivet.
                  • 34827
                  #68
                  I posted the part # earlier in the thread.
                  • MikeE30325i
                    • 2356
                    #69
                    my e30 didnt have a fan for a few weeks of driving and the temp would stay between the 1/4 and 1/2 mark. but stting in traffic for more than 3 minutes the temp would start to rise, and quickly. not good. i would leave the fan on and not have to worry about the car overheating in a drivethru or in traffic or something.
                    • e304me
                      • Feb 2006
                      • 1374
                      #70
                      I have an electric fan on my m42. would it be necessary to put in the lower temp fan switch when the thermostat is 88 degress? seems like the t stat would just be opening and closing all the time if i did.
                      Also i tried to test the fan using a match on the sender but the fan never came on, however, when i jump the pins on the connector for the sender it works, so i guess i need a new sender.
                      • rwh11385
                        lance_entities
                        • 18403
                        #71
                        No, NOW its an old ass thread.
                        Rob,
                        Is Parkerbink's statement correct - you moved the fan to do this?
                        Now it is a really old ass thread...
                        • lukem23
                          • Mar 2008
                          • 295
                          #72
                          it should run better because there isnt that extra coming from the engine.
                          • rwh11385
                            lance_entities
                            • 18403
                            #73
                            I noticed a strange sound when my engine was running... looked and noticed 6 out of the 9 fan blades were broken. Ordered the fan clutch / E39 oil filter cap wrench from TMS along with the coolest $10 part nut that replaces the fan.
                            I searched for threads on how to remove the fan... and laughed when it took 5 seconds and almost punching me in the face to get it started off. Removed it and the shroud, installed nut.... done.
                            Ordering the E36 switch, and water wetter. Don't think cooling will be much of an issue. If it is, and i ruin the engine, M50 time.
                            • CCR Engineering
                              • Jan 2009
                              • 41
                              #74
                              I run a 16" universal fan on my M42. It clips to the radiator and I use a fan controller I got at Orielly's with it. I think it was about $75 total and it's preset to come on around 200 degrees and it has a remote wire I hooked to the AC so both the stock and the new electric fans are on when the AC is on. I just pulled the fan off the clutch and left the clutch there. Cleans up the front a lot without the shroud.
                              • Psyops
                                • Aug 2007
                                • 76
                                #75
                                Any idea how much space there is to mount the fan there? The ones I am looking at are about 4" thick.
