Engine Fan Delete
  • christophbmw
    • Mar 2004
    • 363
    check out: www.autoloc.com they have some pretty sweet cooling stuff.
    '91 318is
    • e30Matt
      • 5077
      If I wire the stock "pusher" fan to a switch to turn on/off, will it be enough without the engine fan to keep it cool if I'm sitting still? I'm contemplating doing this.
      • X2theZ3
        • Mar 2004
        • 932
        Is that ultra thin one adequate for daily driving?
        don't know - the list CFM's I think - Most of those fans are for street rods - BIG american blocks...I think they can handle a m20 at idle during the summer.
        George,
        Are you using an electric fan for you m30 swap? I'm still deciding on doing the electric thing or stock fan?
          • 34844
          I think it would be, the stock M20 clutch fan isn't going to be moving that much air at 650rpm anyway. $75 plus $20 for a mounting kit sounds like a good deal.
          • Beej '86 325es
            • 2639
            My A/C compressor is dead, took out the mechanical fan, cut the compressor belt, and just let the auxiliary fan do the cooling. Been working fine for about 2 years now, plus I can turn it off when I'm on the interstate.
            -Brandon
            '86 325es S50
            '12 VW GTI Autobahn DSG
            '03 540i M-Sport (sold)
            '08 Jeep SRT-8 (sold)
            For sale:
            S50 TMS chip for Schricks
            • e30Matt
              • 5077
              So you use the A/C button to "flip" the aux fan on and off?
              • george graves
                • 20003
                Yes, you can only use the m30's crank/normal fan in "engine position 3" The puts the motor really far back - almost sitting on the firewall, and expect to have to pound out some clearence on the tranny tunnel.
                "Position 1" has no room for a raiator in it's normal place(engine TOO far forward) - a custom radiator has to be made to fit behind the grill..
                Position 2 is where it's at - 3 is just too tight for comfort.
                George Graves
                Originally posted by Matt-B
                • drifty30
                  • May 2004
                  • 135
                  go with a flex-a-lite black magic. i think it pulls more CFM than most other fans and it looks the best and is pretty thin. Also, it fits my radiator very well. i just wired it straight to my battery and hooked up a toggle switch right next to the shifter in the console. the problem there is that you have to remember to turn it on/off. lets the car warm up a bit quicker in the winter though. (for those of us that have snow)
                  • Beej '86 325es
                    • 2639
                    Yup. The only problem with this that I have is that the idle raises maybe 50-100 RPMs to account for the added load the compressor would normally add. I tried unplugging different wires from the back of the switch, but none of them fixed the problem.
                    -Brandon
                    '86 325es S50
                    For sale:
                    • nateb
                      • Apr 2004
                      • 54
                      While were on the subject what is a good replacement radiator that is thinner than the stock unit and cools at least as good?
                      • hella 325
                        • Sep 2004
                        • 380
                        My AC is gone, when i press teh switch it does nothing at all. My Gf's dads e30 a/c also deleted but his raises idle...duno what thats all about
                        Russell
                        1987 325is
                        1992 240sx coupe
                        1994 525i
                        • parkerbink
                          • Jun 2004
                          • 10138
                          Beej are you using the ac fan in it's stock position in front of the radiator, or did you move it?
                          I would love to do this if I can just remove the fan & clutch.
                          • Skafrog
                            • 1732
                            Wow, this is an old ass thread.
                            I removed all my A/C components, I took everything out, the ziptied the fan on the front side of the radiator, and hooked the A/C fan back up to its stock harness.
                            Works great.
                            NASA MidSouth TT Director / GTS2 #018
                            Mods: Coastal PS Fluid, 10w40 Oil
                            Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
                            • parkerbink
                              • Jun 2004
                              • 10138
                              So, in order to use the air conditioner's electric fan it is necessary to move it to the radiator side?
                              Thanks
                              • demlotcrew
                                • May 2004
                                • 297
                                See here for more info of how to wire it into the E30 fuse box,
                                http://com4.runboard.com/be30zoneforum.ftechhelp.t4001
                                Andrew
                                Andrew AT E30zone.co.uk | H23-is | S14
