Vibration of doom
  • NcTurnL
    • 169
    Vibration of doom
    hey guys
    ok here is my problem
    My car rides very smooth up to 75mph, right after that the whole car starts vibrating, at 80mph+, it like the car is about to come apart, feels like a damn earthquake, lol.
    The front wheels have been balanced, the rears, well I dont remember the last time but the car rides very very smooth UNTIL 75 mph.
    Any suggestions?
    btw. the car does need an alignment, not a major one, but could that have anything to do with it?
  • backtrail69
    • Jul 2005
    • 4471
    Worn Ball joints, tie rods or Control arm bushings are my guess. Double check the balancing... sometimes those tire jockeys can really fuck shit up.
    :: PNW Crew ::
    '87 325 4dr, '74 2002
    • Farbin Kaiber
      Lil' Puppet
      • 29502
      those speeds sound like tire balance, or rim mounting, if hub/wheel not centered...
      • moatilliatta
        • 6150
        can a worn flex disk or a out of balanced drive shaft do this?
        @Zakspeed_US
        • Jean
          • 18228
          Put the car in neutral at speed and see if the noise is still there..mine was pretty bad when the guibo failed, it would only vibrate during acceleration and in gear...
          • NcTurnL
            • 169
            I'll check it while the car is in neutural at those speeds.
            Also, if the wheels are not centered on the hub, then how do you center them on the hub?
            • whiltebeitel
              • Apr 2007
              • 2098
              I had the same thing, with clunking. it was a bad u-joint in my driveshaft. replaced it with one from a parts car. fixed everything!
              '89 325i track sloot
              '01 530i daily
              -Enginerd
              • NcTurnL
                • 169
                I guess that could be it also, hmmm
                The vibration does not come from the steering wheel, it feels like the entire car is vibrating....eh. If it mattes any, I have some cheap tires in the front....
                But how could I really check the U-joint?
                • PiercedE30
                  • Apr 2005
                  • 4220
                  Legion of Doom is making a new hide out under your car.
                  My 2.9L Build!
                  • NcTurnL
                    • 169
                    lol
                    • whiltebeitel
                      • Apr 2007
                      • 2098
                      Lift the car up, hold the DS on either side of the u-joint, and if you can feel any slop, that's the u-joint. Also check for missing weights, this could also cause the problem.
                      '01 530i daily
                      -Enginerd
                      • NcTurnL
                        • 169
                        I'll check that
                        But where are the weights usually on the DS?
                        • whiltebeitel
                          • Apr 2007
                          • 2098
                          well, if any were missing, you could see the off-color spot with old glue on it. they should be along the length of the drive shaft. different distances balance differently.
                          '01 530i daily
                          -Enginerd
                          • moatilliatta
                            • 6150
                            i always though that a off balanced driveshaft would give you vibrations around 25 mph
                            @Zakspeed_US
                            • B3M2W5
                              • 283
                              Check your guibo(flex disc) and check the carrier baring in the middle that can also be bad and causing it. I had both go out on my car and it sounded like i was running over continuous pot holes in every gear it was really bad.
