Question Re: Your Nuts
  • Jon325i
    • 6934
    To be very specific, your M20 engine mount nuts. I've got to replace my engine mounts this next weekend and I will be installing a pair of IE motor mounts (the yellow urethane jobbers - see below). I was wondering if the thread pitch on the bolts was identical to those of OEM M20 engine mounts. Just trying to clarify what hardware I'm going to need when I get started.
    TIA.
    Jon
    Rides...
    1991 325i - sold :(
    2004 2WD Frontier King Cab
    RIP #17 Jules Bianchi
  • moatilliatta
    • 6152
    I sure hope they come with it..
    @Zakspeed_US
    • blunttech
      • 12850
      they wont. maybe they are supposed to but someone will fuck up at ireland. i cant speak for the m20 mounts but the ones i have for my M2 that look identical accepted the same nuts.
      sales@blunttech.com
      www.blunttech.com
      Like us on Facebook
      • E30Idea
        • Mar 2007
        • 2196
        Yea they should come with all hardware needed. Otherwise the stock nuts will work just fine.
        ** Lot's of M20 turbo parts for sale.**
        Turn key track car.
        http://www.r3vlimited.com/board/showthread.php?t=222066
        • Jon325i
          • 6934
          These mounts didn't come with any hardware - hence the purpose of this post. A friend sold these mounts to me for stupid-cheap since he sold his E30 - they are used, but they weren't on his car for long before he parted it out.
          I've heard of the stories re: Ireland and their hit-or-miss success with customer service. Its a real shame because they produce some great stuff for our cars that are reasonably priced.
          Jon
          Rides...
          1991 325i - sold :(
          • Jean
            • 18228
            My m10 IE mounts came with the self locking nuts on them ... fwiw
            • Dave
              E30 RAT
              • 11675
              take one to the hardware store and dig through the metric bins and find ones that fit.
              Current Cars
              2014 M235i
              2009 R56 Cooper S
              1998 M3
              1997 M3
              • Jon325i
                • 6934
                That's probably what I will wind up doing.
                Jon
                Rides...
                1991 325i - sold :(
                • Jand3rson
                  • 37587
                  What, you mean...
                  • whowhatwhere
                    • Aug 2007
                    • 259
                    m8x1.25 /thread
                    • Jon325i
                      • 6934
                      Originally posted by whowhatwhere
                      m8x1.25 /thread
                      Noted. Thanks!!!
                      Jon
                      Rides...
                      1991 325i - sold :(
                      • FredK
                        • 14762
                        Hm, so the mounts have smaller-than-stock studs? I am fairly certain that all E30 stock engine mounts have M10x1.5 studs.
                        • De //m3
                          • 165
                          Take the mount with you to be sure...and make sure you buy SELF-LOCKING. Suck to have one of those come loose...
                          2001 330i - In the garage.
                          1986 335is - 325e with Euro 735 M30B34, Under Construction.
                          1989 E30 ///M3 - Sold.
                          1975 2002 - Sold.
                          • Jon325i
                            • 6934
                            Well I got the problem resolved. I had to go to my friends' shop to pick up some driveshaft hardware and guibo to complete my upcoming project and I brought the IE mounts with me. I showed him these mounts and a quick trip to the supply bins yielded exactly what I needed. 4 new nuts & 4 new lock washers for $1.
                            Can't beat that deal with a stick. Now I can fix da whip.
                            Jon
                            Rides...
                            1991 325i - sold :(
                            • E30_fiend
                              • Apr 2006
                              • 7348
                              Why did you get lock washers? The mounts should use either nylock nuts or locking nuts with the oval holes and just a flat washer.
                              If you got just regular hex nuts then you should get the right ones. Do not use a standard nut and a lock washer. There is so much vibration in that area that even a lock washer can start to loosen and the nut may back off.
                              Just FYI
