headlight issues- turn on brights and get no brights and one low beam shuts off.
  • clydesdale
    • 631
    I am not sure what the heck is wrong with this thing, but the low beams are fine, switch to high beams and only the right low beam stays on. All other lights are off. Any ideas? Thanks.
  • Northern
    I like cupcakes & sh!tboxes
    • 5284
    Sealed beams? If so, the one lowbeam goes out because it's a two filament bulb with the "high" filament burned out.
    Highbeams could be burned out, fuse dead, or otherwise check the plug with a multimeter to see if you get power there
    Originally posted by priapism
    Originally posted by shameson
    • Dawskip
      • Feb 2018
      • 242
      If one of your filaments are dust and you need a new set of headlights, I have a clean set of ellipsoids I can sell you for cheap
      • clydesdale
        • 631
        I thought that when you put the brights on, all 4 sealed beams go on. Instead, turn the highs on and not only do the inside high beams stay off, but one low beam goes out. Does that help pinpoint? Thanks.
        • moatilliatta
          • 6158
          Check fuses, Check 12v at your head light connectors.
          Id check the ground also at head light connector. Probably just bad bulbs.
          @Zakspeed_US
          • 101
            • Jul 2011
            • 764
            If you've got an '87 it originally came with sealed beam headlamps. The outer bulbs have two filaments ... one for low beam and one for high beam. The inner bulbs just have one filament for the high beam.
            If the car has been upgraded to ellipsoids from a later model car or to euro headlights, there is just one filament in each of the four bulbs.
            The wiring on the '87 does not support ellipsoids or euro headlights without some modification. We put a set of ellipsoids on our '87 es and had to do some creative wiring with diodes to get the low beams to stay on when the high beams were switched on.
            101
            The E30 collection:
            1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
            1987 325is - Delphin / Black Sport (son #3's)
            1987 325i Convertible - Triple Black
            1989 325iX Coupe - Diamondschwarz / Black Comfort
            1990 325iX Coupe - Sterling Silver / Grey Sport
            1981 Fiat 124 Spider 2000 - Green / Tan
            1998 Volvo V70 GLT - White / Tan
            1998 Volvo S70 T5 manual - White / Taupe
            2001 Ford Windstar - Silver / Grey (parts hauler)
            2006 Lexus GX470 - White / Tan (tow rig)
