Spectra brand in-tank fuel transfer pump 84-87 cars?
  • alpinewhite318i
    • 134
    Has anyone used the Spectra brand fuel transfer pump for 84-87 build cars? They VDO appears to be NLA. Here is the link of the part:
    https://www.amazon.com/Spectra-Premi.../dp/B00FWQIFDG
  • moatilliatta
    • 6157
    We run a race car and use an early spectra lift pump on both sides to a swirl pot. They seem to be working ok. The rubber material that mates the pump to the mast seems cheap but working ok. Not a whole lot of time on them, but seems ok.
    Also have one in my street car on the driver side to feed passenger side main pump. Still only been in there for a few years and gets driven rarely.
    Id say quality is above normal for cheap aftermarket.
    @Zakspeed_US
    • JGood
      • Jan 2004
      • 7959
      The OEM VDO pump is not NLA, but it is a piece of shit and costs about $300. Part number 16141179415.
      I had enough of the OEM pumps and aftermarket pumps dying over the past 20 years, so I did the m42 single pump conversion. You could buy a new or used OEM 318i pump, and use it as-is, or drop in a new $75 Walbro into the housing. Then you can delete the external pump and run some new fuel line, and never worry about your fuel system again.
      e30 restoration and V8 swap
      24 Hours of Lemons e30 build
      • alpinewhite318i
        • 134
        Ok thanks for the input on the Spectra pumps. I would agree the VDO pumps are terrible. I didn't know you can still purchase them. But for $300 that is way to much. Does the early fuel level sender work with the 318i pump? Or does that have to be modified?
        • JGood
          • Jan 2004
          • 7959
          You would swap the whole m42 sender assembly in. The difference between the two is the output hose is the standard 8mm, instead of 12mm, so you'd have to replace the hose across the tank. But then you just connect that right to your hard line under the car, and that's it, no more fuel issues.
          • alpinewhite318i
            • 134
            I think I am going to try that later on. Already ordered the Spectra transfer pump from Summit Racing. I am surprised my main fuel pump in not making any noise since my transfer pump is not working.
            • Sunnyledge
              • Nov 2017
              • 221
              I have both the Spectra pump and Spectra tank. I could’t install the pump with the provided O ring. Needed an OEM O ring which is a little more pliable.
              • KanE30
                • Aug 2019
                • 4
                Sorry to hijack. Would a 3.5 bar pump work as a transfer to main pump or is it too high? I’ve already purchased it
                • alpinewhite318i
                  • 134
                  I used the factory o-ring for the Spectra transfer pump and had to use oil filter pliers on the notches to actually tighten it. It was that hard to get on.
