Using braided stainless steel fuel hose?
  • bimmerboy8912
    • 34
    Looking for opinions here...
    One thing to keep in mind for this question is that cost is not a concern (hypothetically).
    Has anyone used braided stainless steel PTFE fuel hose on a daily driver on the underside of the car for fuel delivery/return?
    I want to go this route, but I want to know what are the benefits, challenges, etc?
    I've heard that the hose can rub on the body and can rub off any underbody coating...true/false? (I don't know why this happen if there are properly spaces hose clamps)
    Thanks!
    The BMW Bible: http://www.realoem.com
    2011 328i xDrive Sedan - DD
    2002 530i - sold
    1994 525i - gave to dad
    1991 345is (M102 Swap) - sold
    1985 325e - sold
  • cheffy30
    • Sep 2016
    • 1159
    my 30 year old hard lines on my daily are fine. why mess with them? sent from hell using tapatalk
    '90 325i sedan daily driven
    '85 325e coupe also a daily
    • dnguyen1963
      • Nov 2011
      • 2649
      Thumb down from me.
      • bimmerboy8912
        • 34
        Put in a new high flow fuel pump and upgrading the whole fuel system. The new hose/lines will have to route a different way (part of the way) because of the new pump location.
        2002 530i - sold
        1985 325e - sold
        • bimmerboy8912
          • 34
          Originally posted by dnguyen1963
          Thumb down from me.
          Why's that?
          2002 530i - sold
          1985 325e - sold
          • hkv
            • Jul 2019
            • 274
            if your upgrading your fuel system then you might as well go with the braided if that's what your interested in, it looks cool. the braided should be easier to install than hard line if your starting from scratch. bending the hard lines neatly would be the challenge i think. although I think the bigger diameter of the braided would present a disadvantage to hard steel line.
            • Caperix
              • Feb 2018
              • 190
              Good cunifer fuel lines are easy to bend & look less boy racer than a 6 foot length of steel braided line. You can flair the ends to take an fittings & just run short lengths of braided line. How much did your fuel pump outlet move with the upgraded parts?
              • moatilliatta
                • 6149
                You can also go to most hose shops and get stainless tubing.
                I would keep with tubing over hose.
                @Zakspeed_US
                • dnguyen1963
                  • Nov 2011
                  • 2649
                  Originally posted by bimmerboy8912
                  Why's that?
                  For a daily driver, there is no real benefit except for the look.
                  • cory58
                    • 1021
                    Wider diameter braided hoses will not fit in the plastic clips that hold the OE hard lines. Those clips also hold the hard brake line. You will have to redesign the mounting if you go with braided. OE supply and return lines are still available. Just replaced mine.
                    Cory
                    1992 325i Cabrio
                    1988 320i Touring
                    2000 M5
                    1977 530i
                    2015 328i - Euro Delivery/Performance Center Delivery
                    BMWCCA
                    E30CCA
                    • iansane
                      • 1342
                      I ran braided line on another car I revamped the fuel system on about 15 years ago. It's still holding up fine feeding a turbo LSx. However, I did it because I was young and uncomfortable bending/flaring hardline. If I were to do it again I'd run hardline and flare fittings. Easier to fix later on if there are issues and looks better to me.
                      84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
                      • TobyB
                        • 5261
                        Nah, me neither.
                        Use flexible tubing where it needs to be,
                        rigid where it doesn't. Even on racey cars, the
                        sanctioning bodies prefer a hardline.
                        One reason being, it's far easier to see if it's damaged.
                        You can crush PTFE tubing, and the braided shield will re- form,
                        but the tubing inside may still be compromised.
                        But it's your car- you certainly won't kill anyone if you do it reasonably well!
                        t
                        doesn't think it matters.
                        • jbontke
                          • Mar 2019
                          • 449
                          I see a lot of shows where they use "rubber" fuel like the length of the car, it's less labor. I would do that on something i want to get running now. But in the long run, I would use a hard line. Nickle copper is easy to bend and cheap.
